Car electrics wiring question this time
ok
want to wire up the RS this weekend properly, similar to how Adam (BlackRS) has done his, but have a question.
Using for example something simple like say a fan switch, wired like this.
Wire from fan to the battery, with a fuse box and switch in the middle.
what do i do about relays? do i need a relay and where does it go? do i just wack a relay in the middle somewhere or does it have to go in a certain place (before the fusebox etc)
It goes where your switch is in the order you have typed it out. Your switch works the relay, not the fans...
Originally Posted by Gra
oh sort of like this
forgive the crap piccie but wanted to make sure i have it correct
Ask Tiff for his super fan wiring diagram!
40 amp 4 way fuel relay i used for my fans
wire the earth from the fan direct to battery
live from fan to relay
live from battery to relay
earth wire to relay
wire from a live source (fused) with switch inline to relay
obviously you need the correct relay and certain wires have to goto correct pins
this does cut out the OE fan switch mind
earth wire to relay
kosienutter
31
Aug 22, 2015 09:55 AM
yawiejon
15
Aug 9, 2015 06:36 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
