advice on removing st 170 engine please
i crashed my st on xmas day now im stripping it, i have removed most of the front and just after a bit od advice on the best way and easyiest way to remove it, i dont have a engine lift but do have a pallet and pallet truck.
also if any1 can tell me the main things to disconect before removing, also is it best to split the engine from the box first, heres pics of how it is at the min.
any help would be great
Disconnect the hubs and shafts then support the sub frame undo the gearbox and engine mounts and subframe and it will all come down on the subframe, you may have to remove wishbones too
If your taking the engine out with the sub frame then just undo the sub frame bolts gear upper mount drivers side mount and the 6 little bolts the shock are bolted to then you can drop the whole thing out without messing round with the suspension, drive shafts and wishbones.
I did this on my own without a engine hoist
all i did was undo the nuts on the drive shafts first then disconect the de-cat and gearbox linkage and all cooling system and wiring then just undid the torque link and and engine mont and gear box link with a jack under where the engine and gearbox meets and just lowered the unit down and the drive shafts jus pop out on there own and your done.
(ps make sure you undo the drive shaft nuts first)
JoeyBoyden
Jan 4, 2024 02:36 PM
track.focus'd
Aug 12, 2015 05:53 PM
