Help.. My Car wont start?
Old Jan 2, 2013 | 02:09 PM
RiggerWrigley's Avatar
RiggerWrigley
Default Help.. My Car wont start?
Hi, I'm a new member please help!!!
I have a Mondeo 2004 TDCi. It has started 1st time every time since I've had it approx 6 months... including 4 times yesterday. This morning and agian this afternoon however it is failing to start. The Imobiliser light comes on for approx 3 seconds before going out when I turn the ignition on. When I try to start the engine nothing happens at all, no noise from the starter motor or anything. I can hear some faint buzzing noises when the ignition is turned on/off. When I parked up last night I switched the engine off whilst I was slowing to a stop, only 10 feet or so before halting.(paniced as all my Sisters and Brothers cars were at the house and my Dad is unwell, thought something may have happened). Thanks for any help.
Old Jan 2, 2013 | 02:16 PM
booner999's Avatar
booner999
Not sure on the 2004 models but try putting the key in the door, turn it to lock, then unlock again. Try that. This should or does on the older models turn the imobiliser off.
Failing that check your fuses.
After that I would be looking at getting it on a diagnostics machine and seeing what that throws up
frsjon's Avatar
frsjon
hello and welcome to the site if you dont have any luck here try www.fordmondeoownersclub.co.uk
Old Jan 2, 2013 | 02:30 PM
STeve's Avatar
Super Moderator
everyday there is a problem posted about mondeo tdci's
Old Jan 2, 2013 | 02:38 PM
RiggerWrigley
Thanks for the replies, I will post on the other board as well. It's a strange one, not sure weather to try jump leads or a jump start?
....Thinking back, last night I got some stuff out of the boot of my car. I used the button on the key to unlock just the boot. I closed the boot without pressing the button to lock the car, not sure if this could be the cause of a imobiliser problem?
Old Jan 2, 2013 | 02:59 PM
Cosnada's Avatar
Cosnada
That wont cause your issue - you can enter the boot with the fob without affecting the immobiliser.
Try the lock method first. If its not that then its deffo diagnostics time.
Old Jan 2, 2013 | 03:05 PM
escortmk3rwd's Avatar
escortmk3rwd
iam a recovery driver and when i pick up mondeo diesels up it either diesel pump gone turbo or injector off
Old Jan 2, 2013 | 03:12 PM
stephenbatey's Avatar
stephenbatey
I was thinking the same.
Old Jan 2, 2013 | 03:13 PM
escortmk3rwd
are and fogot floating clutches
Old Jan 2, 2013 | 03:50 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
It may be something very simple.
The fact the PATS light comes on and then goes off suggests that the key is being recognised, if it wasn't, the light would flash rapidly.
Check to see if you are getting power down to the solenoid on the starter motor. If so, good chance it's a starter motor fault so give it a bash and see what happens.
If there's no power, it may be a wiring or relay issue in which case it'll need investigation. Try powering up the solenoid manually with the ignition on and see if it starts. Make sure it's not in gear though!!
The rule is try to not overlook the basics, all too often I get called out to cars people think there is something major wrong with their car when it turns out it's actually a flat battery.
Old Jan 2, 2013 | 04:22 PM
RiggerWrigley
Ok, I've tried both keys in the lock no luck. I've tried jump leads from my friends truck. I've rang OMC Ford who said the keys and chip appear to be fine by the Red LED working as it should. I've checked all fuses and relays in the fuse box under the bonet. The fella I spoke to at Ford said it sounds like a starter motor problem, as I described how nothing happens at all when I try to turn the engine over. I'm gonna wait for my Brother to get home and try a jump start and I'm gonna book it in at a local garage tomorrow. I'm not spending any big bucks on this as soon as its running I'm trading it in for something better, Ford Ranger maybe?
Old Jan 2, 2013 | 04:25 PM
escortmk3rwd
if its the starter try tow start never heard key lose its code mind
RiggerWrigley
Thanks for the advice but beyond checking fuses I'm pretty much useless when it comes to working on cars. I only got the Mondeo as a run about as it had FSH and low mileage for its age. That and I never had a problem with my Escort RS Turbo or RS2000 when I was a young boy racer (they were the days).
Old Jan 2, 2013 | 04:27 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Don't be tempted to bump or tow start it as I've come across quite a few that have jumped teeth on the timing chain when this has been attempted.
Old Jan 2, 2013 | 04:30 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Give the AA or RAC a call if you're with someone like that and get them to have a look.
Old Jan 2, 2013 | 04:55 PM
escortmk3rwd
bump a few use 2nd or 3rd transit front wheel drive and connects ive towed loads to start
RiggerWrigley
Default It's alive ! ! !
Well it's working again now! Not sure what fixed it? My brother arrived so I got the tow rope out to try bumping it and to take it to the garage if it failed to start. I emptied the boot to find the towing eye, inserted the towing eye on the front of the car and attached it to my Brothers van. I got it put the ignition on, put the drivers window down and sounded the horn to signal to my brother we were ready to go. Before he set off I decided to give it another try and it sparked into life! I sounded the horn again to tell my brother to stop?
I think it's time to get a new car... I fancy a Ford Ranger, plenty of room for all my gear and I could have a little off road fun.
Old Jan 2, 2013 | 04:58 PM
BigChuck's Avatar
BigChuck
are you getting a new car because this failed to start once?
Old Jan 2, 2013 | 06:07 PM
RiggerWrigley
Kind of, I need it to be reliable as I work shifts and need the car to get me to and from work early mornings and late nights. It not starting this morning cost me Ł20 in a Taxi to get to work and by the time the Taxi arrived I was late. I also had to get the bus home which took an hour when my normal drive takes 15 mins. If I had a work van and only used the car for personal use (like my last job) it wouldnt really be an issue.... I just hope it starts in the morning!
Old Jan 2, 2013 | 06:58 PM
RichieST's Avatar
RichieST
What happens on these is the dual mass flywheel starts to wear and metal shavings clog the starter motor up until it wont turn any more. I bet this is happening. I'd suggest whipping the starter out and seeing if it is clogged up with crap.
Old Jan 2, 2013 | 07:58 PM
RiggerWrigley
This sounds like the problem, when I try to fire the engine nothing at all happens, the starter motor doesnt even click. With jump leads it made no difference. It started at tea time but I tried it again at 2000 and the problem was back. This time I bump started it on a hill in 3rd gear and it started up. I then drove up and down the street for 5 minutes and it runs fine. I turn it off and it will start again no problem until I let it cool down then it returns to the original problem.... I'm gonna have to take it to the garage tomorrow as I wouldnt even know where to start looking for the starter motor, never mind have the ability to whipp it out! I wish I would have done some sort of mechanical work back in my colledge days.
Old Jan 2, 2013 | 08:11 PM
escortmk3rwd
i said earlier there no probs in bump starting them done if for years but sometimes it starts and doesnt might be sign pumps on its way out
Old Jan 2, 2013 | 08:15 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
I've recovered quite a few now that have jumped chains due to attempted bump starts.
Old Jan 2, 2013 | 08:21 PM
escortmk3rwd
ive been doing recoverys around newcastle and gateshead for years and get hired off a lot of garages and never had a single one do it yet because there a twat to bleed up after running out of diesel and turning them over burns starter out so tow them and start after a while
Old Jan 2, 2013 | 11:06 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
We all have different experiences mate
Old Jan 3, 2013 | 11:58 AM
Brendan's Avatar
Brendan
struggling with reality
just be gentle with the clutch when bump or tow starting this then you will be fine...
If you are not gentle with the clutch then you throw the dice and if your number comes up expect the above!
JoeyBoyden
Jan 4, 2024 02:36 PM
Fordmad!
Sep 26, 2015 05:24 PM
Adam-M
22
Aug 10, 2015 10:46 AM
xr_craig
Aug 7, 2015 06:00 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
