Handbrake not working on one wheel - what did I miss?
Old Dec 2, 2012 | 06:15 PM
tsutton's Avatar
tsutton
Default Handbrake not working on one wheel - what did I miss?
Hey all,
A few weeks ago, I noticed that the rear disc of my car - Ford Focus ST170 (52 reg) - has a bit of rust on the braking surface on the disc and I did a quick test by putting the hand brake on, 1st gear enabled and slowly lifted the clutch and the car "tilted" a bit, which tells me that one of the wheel is still free moving even with the handbrake applied.
After some investigation, it turns out that the slidng pins has been seized. So this afternoon, I had the chance to roll up my sleeves and tackled the seized caliper sliding pins.
I have taken them apart, giving the sliding pins & other parts a good clean & greased them up, I put them back together. Then went for a test drive, all is good. But when I did the same test (as above), the handbrake still only applied to one rear wheel and not the one that I did the job of this afternoon!
What am I missing?
Any help would be grateful.
Thanks all.
Old Dec 2, 2012 | 06:20 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
its not just the sliders that sieze up.
the actual handbrake mechanism and piston can seize up. The handbrake mechanism is another seal that can fail causing a caliper to sieze up over time.
My cossie calipers siezed up on the handbrake mechanism and needed re-furbing.
also could be the cable.
Old Dec 2, 2012 | 06:27 PM
Chaz888's Avatar
Chaz888
Maybe the cable is stiff or caliper needs a stripdown could be self ajuster not working.
Old Dec 2, 2012 | 07:39 PM
martysmartie's Avatar
martysmartie
If the sliders had seized, then the pads on that side will be worn, so you most likely have a 'imbalance' anyway!
Martin
Old Dec 2, 2012 | 08:01 PM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
I'd put money on a seized cable causing the caliper slider to seize - so you've fixed the symptom, not the cause.
Old Dec 2, 2012 | 08:36 PM
tsutton's Avatar
tsutton
Thanks all, so which one should I start investigating, i.e. the 'easiest/more likely' before taking it further?
Old Dec 2, 2012 | 08:37 PM
tsutton's Avatar
tsutton
I checked both pads when I took them apart and both of them has the same amount of pads material left.
Old Dec 3, 2012 | 09:45 AM
tsutton's Avatar
tsutton
Is this any good?
http://www.ebay.co.uk/itm/170821777012
Might be easier to replace it and tackle the orginial caliper at a later time as I have MOT coming up.
Old Dec 3, 2012 | 10:17 AM
DanW@FastFord
Spelling Club King!
Get the car in the air, get someone to operate the handbrake and see what does and doesn't move! Then disconnect the handbrake cables from the calipers and operate the handbrake again. It will be obvious where the fault is.
Old Dec 5, 2012 | 06:16 AM
tsutton's Avatar
tsutton
When I pulled up the handbrake, the cable got tighten, so the cable is deffo not broken.
I wonder if the handbrake mechanism within the caliper that is stuck over the time? Would WD40 or penetration spray help?
Old Dec 5, 2012 | 06:31 AM
Do as Dan said matey.Get someone to look underneath and then work the hand brake.
Old Dec 5, 2012 | 12:22 PM
martysmartie
Just re-read, it sounds as if your brakes were not applying on said seized caliper, it's usually the other way round, i.e. they bind, therefore the pads wear.
Even so, it's most likely that there is a difference, it's just you have the reverse effect, i.e. the opposing wheel on the axle has less pad material as it's been doing all the work, opposed to the seized one that hasn't.
Martin
Old Dec 6, 2012 | 12:49 PM
higgsy91's Avatar
higgsy91
Zetec Turbo Baby Yeahhhh
check that the cable housing is seated on the provided lug/bracket near the caliper. I'm pretty sure if the cable housing moves too then it won't work.
Rob
Old Dec 6, 2012 | 06:12 PM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
I must sell about 20 nearside rear focus calipers a week. Dead common for them to seize up
Old Dec 6, 2012 | 09:01 PM
tsutton's Avatar
tsutton
So I guess it's easier to replace it rather than trying to tackle the problem?
Old Dec 7, 2012 | 07:06 AM
Daveysaff's Avatar
Daveysaff
Swapping the caliper takes about an hour from start to finish after you've bled the brakes up, if you strip and rebuild it who knows!
Just dont buy a used one if you go down the replacement caliper route
Old Dec 7, 2012 | 07:30 AM
PAUL S's Avatar
PAUL S
My focus failed the mot on this, brakes were working fine both sides, just would not lock up on the handbrake, even the lever felt fine. Turned out to be a seized cable pulling to one side.
Old Dec 7, 2012 | 07:33 AM
tsutton's Avatar
tsutton
Thanks all, make sense to replace it to save the hassle in the long run.
Cheers all.
Old Dec 8, 2012 | 09:35 AM
tsutton's Avatar
tsutton
Result of the brake test...
Brakes - Rear axle
Left: 181 Brake Forces (kgf)
Right: 217 Brake Forces (kgf)
Parking Brakes
Left - 13 Brake Forces (kgf)
Right - 179 Brake Forces (kgf)
Does it mean the caliper itself is indeed seized? Wanted to be very sure before I order the part!
Last edited by tsutton; Dec 8, 2012 at 09:37 AM. Reason: entered wrong numbers for brakes
Old Dec 8, 2012 | 09:59 AM
Daveysaff's Avatar
Daveysaff
There a little cam inside the caliper thats connected to a lever that in turn connects to the cable. This operates the parking brake.
If the cam over rotates, the piston has to come out to reset it which means ballache getting new seals, bleed nipples and hoping the piston isnt corroded etc
Thats how the brake engineering rep explained it to me anyway!
Looking at those results though, could be the combination of a cable and the caliper tbh. Neither should be expensive to sort
Old Dec 8, 2012 | 10:18 AM
tsutton's Avatar
tsutton
Cheers, it's never easy, eh?? ;D
Will take the wheel off & remove the cable from the handbrake mechanism of the caliper and see what's not working, etc.
Old Dec 8, 2012 | 11:58 AM
tsutton's Avatar
tsutton
Right, I have had a look and can confirm the handbrake cable moves freely so that rules out seized cable. The handbrake mechanism itself on the caliper however does not move freely and was actually very hard to twist to operate it.
So I will order a new caliper.
Thanks for the help, everyone!
Old Dec 18, 2012 | 11:00 AM
andrewhowell's Avatar
andrewhowell
If the hand-brake cable doesn't move freely the check the wire and fix the problem.
Old Dec 18, 2012 | 03:38 PM
tsutton's Avatar
tsutton
Thanks but you may want to check the latest posts.
JoeyBoyden
Jan 4, 2024 02:36 PM
steerfromdarear
28
Jan 29, 2016 06:14 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
Red_bull
Aug 9, 2015 08:34 AM
