Help focus diesel bleeding !!!!!!
Old Aug 21, 2012 | 08:44 PM
rst2dan's Avatar
rst2dan
Default Help focus diesel bleeding !!!!!!
Hi, I an struggling to start my focus diesel after changing the fuel filter, it's a 2010 2l tdci, I have filled the filter bowl up and filled the pipe up to take out the air bubbles, I starts but dies and won't drag any more fuel through!!!!!!! Thanks in advance
Old Aug 21, 2012 | 09:01 PM
mechanic28's Avatar
mechanic28
they are bastards mate really are as far as i remember there is a manual prime pump somewhere near the filter and a bleed screw you undo although not 100% sure
Old Aug 21, 2012 | 09:02 PM
Doug2300's Avatar
Doug2300
sidewaystastic
I often end up having to put an old xr3i fuel pump between fuel filter and pump to get them to bleed. Have seen them crank for ages before they start and continue to run.
Old Aug 21, 2012 | 09:06 PM
rst2dan's Avatar
rst2dan
I have been trying for nearly 2 hours, I cant see any manual pump in line!!!! I had a 2006 2l diesel before and never had a problem, it's like it won't suck any more diesel up!!!!!
Old Aug 21, 2012 | 09:10 PM
botters's Avatar
botters
competant bodger
i use my fluid extractor for these (and all diesels nowerdays tbh) its the vacuum type for draining sumps through the dipstick, i just attach it to pipe from filter to pump and give it a couple of pumps and they always start immediatley, before i had one of these i used to fill the filter to the brim with diesel then tow them until they started
Old Aug 21, 2012 | 09:12 PM
mechanic28's Avatar
mechanic28
they are a bitch mate they really are fill up the filter and line again get someone to crank it over and crack open the fine lines at the injector one at a time until you get a squirt of fuel from each one then she should fire
Old Aug 21, 2012 | 09:16 PM
rst2dan's Avatar
rst2dan
Cheers, will try that tomorrow!!!!!
Old Aug 21, 2012 | 09:19 PM
LHD220Turbo's Avatar
LHD220Turbo
dragging it up the road always works, but the last time someone i know did that, it jumped on the timing chain all that just for a fuel filter chain
Old Aug 21, 2012 | 09:39 PM
botters's Avatar
botters
competant bodger
now that would be gutting! allthough rare, you sure they hadnt changed the oil at the same time as i always like to fire chain driven cars straight up after an oil change to prevent this as i know a lad at vw who told me of some polo's that had jumped chains after being left overnight with the oil drained!!
Old Aug 21, 2012 | 09:44 PM
LHD220Turbo
may well of been, it was a little while ago. I think they guy just ended up scrapping it as he had no end of grief with the car, i think jumping the chain was the straw that broke the camels back!!
Old Aug 21, 2012 | 09:59 PM
COLEYST200's Avatar
COLEYST200
Iv just had to pull Ł10 petrol out of one of these very simpol job to bleed I tuck the out going pipe of the filter and just put a old electric fuel pump on it and sucked it all out and as to the bleeding there is a return pipe next to the filter which I tuck off and put a pipe in it and sucked the diesel throw the pump them put the pipe back on as quick as I could turnd the key with my foot on the floor and after about 5 seconds it started
Old Aug 21, 2012 | 11:04 PM
RS2000CUSTOM's Avatar
RS2000CUSTOM
As mentioned on other replies
This is what I use on a daily basis
Fit new diesel filter
Remove pipe connected to filter housing that goes to the fuel pump on the engine
Use the pump to suck diesel through until about 1/8 - 1/4 ltr has passed through
Reconnect fuel pump pipe
Then start engine
It really is that simple
NOTE - I always replace oil and filter first and restart engine then check oil level etc etc BEFORE beginning to replace fuel filter as this prevents the dreaded cam chain jumping due to a "deflated" chain tensioner
Old Aug 21, 2012 | 11:26 PM
jamie's's Avatar
jamie's
had bother with these before as well
as mentioned get pump between filter and pump
it wont jump the timing chain as the 2litre focus uses the peugeot 2ltr
so its belt driven not chain so no oil pressure required like the old mondeo duratorques
Old Mar 27, 2015 | 06:44 PM
Jonk7892's Avatar
Jonk7892
Default Bleeding help
Have had a lot of trouble on older cars. Even brand new lorrys and forklifts if you've
It the filter full of fuel and still no get some one to crank the engine and give it the slightest sniff of brake cleaner or easy start just enough to make it fire once drags the fuel up a treat.
Old Mar 27, 2015 | 07:15 PM
Welcome to pf. Well done for revivinga 3 year old post.
Old Mar 1, 2020 | 04:08 PM
Landmarc100's Avatar
Landmarc100
Default Use the third pipe
You have the inlet pipe left hand side of the filter, outlet pipe the right side, (PS you dont need to remove these to change the filter,) the important one is just behind the filter and is the return to tank pipe normally with a green fitting, Unclip the red clips which are 2 parts first one comes up the other part goes down. you may need to use a small screwdrive to gentle spread the end to get thgese apart, fit a pipe to the green end and suck fuel out until it runs without a lot of air in it re connect the ends and now start the engine a bring the revs up to 2000 - 2500 for a minute, this sould clear any more air in the system. Job done.
My mate changed his fuel filter on hia astra and did not bleed it, so he called out his breakdown firm, who just sprayed easy starty in it until it bleed its self, not what i would have done but it worked for him.
Old Mar 1, 2020 | 06:52 PM
Mate it's a 5 year old thread/post.
Old Mar 2, 2020 | 04:43 PM
burnzy's Avatar
burnzy
burnzy
to be fair he never come back to say it was sorted, there’s a possibility his still cranking that thing over
And technically it’s an 8 year old thread, just sayin 😬🤣
Old Mar 3, 2020 | 11:21 AM
Ha ha ha ha ha ha funny coooooont lol. It needs a starter motor now cause he has burnt the coooont out cranking the engine.
Old Mar 3, 2020 | 11:26 AM
burnzy's Avatar
burnzy
burnzy
griffo69
Jan 31, 2016 07:57 PM
jayaprakash.panoli
Apr 14, 2015 03:14 PM
J.thanky
Dec 7, 2011 07:28 PM
paceo
17
Mar 23, 2009 04:39 PM
