Wheels and Tyres Wheels and Tyres for all Ford's
Ford Locking Wheelnut Problem
Old Apr 4, 2012 | 05:49 PM
nickscunny's Avatar
nickscunny
Default Ford Locking Wheelnut Problem
I have snapped my Locking wheelnut key
Where can I get a replacement?
Old Apr 4, 2012 | 05:54 PM
Fiddy's Avatar
Fiddy
I snapped the one on my old black mondy. To be fair, it's my fault it snapped, I over tightened the locking nut putting it on, and it snapped when i was trying to loosen it
Don't know if you can get replacements. Push comes to shove, try hammering a socket over the nuts, see if you can get them off, then buy a new set
Old Apr 4, 2012 | 06:00 PM
nickscunny's Avatar
nickscunny
I may end up doing that Craig.
Old Apr 4, 2012 | 06:01 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
i would drop in to local scrap yad and they may have a stash to try, i used to keep them if i scrapped a car and the nuts were either crappy or any were misssing, i have alot of them like yours but if you dont live in norfolk thats no good
Old Apr 4, 2012 | 06:03 PM
nickscunny's Avatar
nickscunny
My key has a code on the side. Is it a case of matching the code?
Old Apr 4, 2012 | 06:07 PM
gouch1's Avatar
gouch1
if they are ford nuts try ford i once did this with a car and got a replacment for a few quid
Old Apr 4, 2012 | 06:09 PM
nickscunny's Avatar
nickscunny
As long as it doesn't cost me the same as a set of new lockers.
Old Apr 4, 2012 | 06:41 PM
wilsonrs's Avatar
wilsonrs
You can order a new one from ford, but they are Ł30 and take week to order
Old Apr 4, 2012 | 06:45 PM
RichieST's Avatar
RichieST
I had this exact problem, ordered a new key which took ages to arrive, and then broke that fucker too
Ended up having the car in the garage for 2 days for them to remove the lockers. Problem with modern fords is there is no space between the nut and the bolt hole for you to be ble hammer a socket or a universal removal tool on to the nut.
Old Apr 4, 2012 | 07:35 PM
romfordrst88's Avatar
romfordrst88
try ebay i lost mine but had the code and one of the sellers matched it and sent me thew new one in a couple of days
http://www.ebay.co.uk/sch/i.html?_nk...at=0&_from=R40
Old Apr 11, 2012 | 09:07 PM
rogerxr3i's Avatar
rogerxr3i
Default hi
When I used to work at Ford dealership we had a master set.
Are they genuine or not?
Old Apr 12, 2012 | 05:33 PM
yunii's Avatar
yunii
poor soul, you gonna have to break alll 4 if you can't find a replacement matching locknut key.yunii
Old Apr 12, 2012 | 07:31 PM
Retro Al's Avatar
Retro Al
RWD IS KING
Go to http://www.dynomec.co.uk/indexEnglish.html they will remove all for around Ł50 only takes half hour.
I charge the same to remove but they are nearer for you to go direct.
Old Apr 27, 2012 | 01:43 PM
Cosnada's Avatar
Cosnada
Can you not take the broken 'shape' out of the nut and get that welded to a standard nut just to try and help you in the interim? I would deffo have a go - especially if it could be tigged as this would be neater and not so proud?
JoeyBoyden
Jan 4, 2024 02:36 PM
Seanyfarrell
Aug 14, 2015 11:37 PM
Red_bull
Aug 9, 2015 08:34 AM
tankybaby66
Aug 9, 2015 07:13 AM
