Mondeo TDCI non start
Old Oct 24, 2011 | 12:23 PM
scaniaomni's Avatar
scaniaomni
Default Mondeo TDCI non start
Hi can anyone help 2004 Mondeo tdci bought it 8 months ago and been running fine. Now cant get it to start after lying for 2 weeks immobiliser light on the clock does not illuminate at all car turns over ok but wont run checked all fuses and cant see anything wrong what next??? Any help appreciated.
Old Oct 24, 2011 | 12:29 PM
phil_focus's Avatar
phil_focus
try charging the battery over night. they can be a bit fussy when the voltage drops a bit.
Old Oct 24, 2011 | 12:42 PM
scaniaomni's Avatar
scaniaomni
Default mondeo tdci non start
hi battery is good turns over untill heater plug light comes on im sure immobiliser light not illuminating means no start up do you know what to check next where is it fed from ???
Old Oct 24, 2011 | 12:49 PM
BRIGSPORT's Avatar
BRIGSPORT
UNAUTHORISED DEVELOPMENTS
Is there plenty of fuel in the car?
Old Oct 24, 2011 | 01:02 PM
B19 JUB's Avatar
B19 JUB
have u tried another key to start it?tbh if it cranks over it doesnt sound like an immobiliser issue.i suspect its either camshaft sensor or injector fault.might even be all the fuel has returned to the tank and the pump isnt pulling it up
Old Oct 24, 2011 | 03:18 PM
BRIGSPORT's Avatar
BRIGSPORT
As above, i recently ran out of fuel in my mercedes vito cdi. It didn't cough or splutter, i just went to the shop, come back out and she wouldn't start!
Started with a tow then coughed and spluttered to a halt about a mile later.
May be worth trying to bump it off and see if that works.
Old Oct 24, 2011 | 10:47 PM
phil_focus's Avatar
phil_focus
i still wouldn't rule the battery out until its had a good charge as they can appear to be fine and crank well but running the starter can make it dip just bellow the required voltage for the electronics to work properly and fire it up. seen it before with my dad's mondeo tdci.
does the immobiliser light illuminate/flash when the car is locked?
Old Oct 25, 2011 | 12:24 AM
scaniaomni's Avatar
scaniaomni
Hi no immobiliser light at all although car locks and unlocks with key button as normal. Tried clock in another car today and red light flashes as it should. Any one have more info on immobiliser circuit?
Old Nov 5, 2011 | 03:28 PM
scaniaomni's Avatar
scaniaomni
Hi 2004 Mondeo TDCI may be injector trouble wont start. Has anyone connected an injector to the common rail but externally on a healthy car. I have tried this today one at a time with each injector, electric connected and engine running (on 3 cyls) each of my injectors from the non running car dont inject any fuel! Surely all 4 unlikely to be faulty, not sure of history on the car 100,000 miles any advice appreciated!
Old Nov 5, 2011 | 05:30 PM
forevaford's Avatar
forevaford
the fuel pumps break up inside, and clog the injectors, all 4!. iv had this a few times now. usually get fault codes first though, and it cuts out on high load, usually restarts for a while before it completely dies. checck for fuel contamination. if it is this, then it needs 4 injectors, fuel pump and tank drain and clean
Old Nov 6, 2011 | 11:07 AM
scaniaomni's Avatar
scaniaomni
hi many thanks can u confirm my test for the injectors is correct ie they should have injected on the good car although connected externally? also pump is still producing pressure? would new injectors just get ruined again? surprised that all 4 are gone i know car had petrol in it previously and bought it as a project to repair any more advice appreciated!
Thanks
Old Nov 6, 2011 | 11:32 AM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
The injectors/pump are incredibly fragile, and buying a 'mis-fuelled' TDCI is never ever going to be a cheap option.
I'd check the fault codes and I suspect you'll have P1211, and P0251. If that's the case then unless the car is incredibly clean, it's not going to be worth fixing.
If you have access to another TDCI try swapping over the cam sensor, and also make sure the fuel filter is filled to the brim with fuel just in case that's why it's not starting.
Old Nov 6, 2011 | 01:48 PM
scaniaomni's Avatar
scaniaomni
has anyone connected an injector externally to see if it works?
Old Nov 6, 2011 | 05:55 PM
forevaford's Avatar
forevaford
how is the injector connected? like normal but spraying into a cup instead of the cylinder? ifso id expect a good injector to spray fuel, all be it a verry fine mist. and yess when the pumps break down, they still produce normal pressure, its the injectors that clog that cause it not to start, and the pump causing the injectors to clog
if you can do the work your self, its 100 for a second hand pump, and around Ł90 per injector (recon)
Old Dec 7, 2011 | 05:45 PM
cossie.con's Avatar
cossie.con
Did you ever get to the bottom of this?
Mik
Old Dec 7, 2011 | 10:32 PM
BRAM's Avatar
BRAM
The connecting a injector to another car won't work unless you have coded the injector into the good car.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
Alun Gregory
Sep 6, 2015 09:40 AM
Bailes1992
Sep 3, 2015 02:17 PM
kevin36
Sep 2, 2015 06:24 PM
