Koni adjustment..
Old Apr 3, 2011 | 10:41 AM
peteh's Avatar
peteh
Default Koni adjustment..
Was going to fit my ahmed springs today, but i dont have the adjuster knob, could anybody tell me which way i should turn it?
Firm anti clock wise? just from what ive found on ebay.
Also how do you do the rears?
cheers, pete
Old Apr 3, 2011 | 10:50 AM
avinit1rs's Avatar
avinit1rs
AV IT!!!
Fronts - Clockwise = firmer
Rears - from memory mine had a sticker under the dust protectors which can be seen when removed from the car, i think it only has three settings on the rear. (there is a small button on the top lip of the lower part of the leg which you press in and turn the top section) Only takes 5 mins to get the rear legs off and back on again.
Would be interested to hear your opinion on the handling after fitting the springs as im considering getting these myself.
Old Apr 3, 2011 | 10:54 AM
peteh's Avatar
peteh
Ok cheers, buy them direct from ahmed, most people add £20 on!!
also ahmed kindly meet me near harlow, very nice guy and full of advice.
Old Apr 3, 2011 | 10:57 AM
martysmartie's Avatar
martysmartie
The rears you have to remove the shock, slide the plastic sleeve down you will then see a button, you have to depress then button and twist the shock, you should have three "Clicks" of adjustment.
To increase rebound you have to turn to the right and make sure the knob releases after!
See here: http://koni.com/193+M5e7f265c5e0.html
Fron the pics it would suggest you turn anti-clock wise for increased damping.
The fronts you can adjust with pliers if you don't have the knob.
+1 for letting us know how you find them
Martin
Old Apr 3, 2011 | 11:08 AM
peteh's Avatar
peteh
give grove a ring, top lads, you 'may' have to wait for another batch to be made though.
£140
marty - that's what i thought /
Old Apr 3, 2011 | 11:15 AM
martysmartie
They lower by 10MM don't they? Still need to sort mine, it's between these or AVO, thing is with Leda (AB) springs are they alot stiffer than standard?
With my current springs which were on it when I brought it (Eibach) are very hard and you feel every bump, it's like driving around in an old steam engine.
Martin
Old Apr 3, 2011 | 11:19 AM
peteh's Avatar
peteh
Ahmed told me it's around 8mm lower, so yeah about what you said, also need to run the koni's on the softest setting to make the most of them.
itll be a few weeks till mine on the road as my rack is knackered!!!
Old Apr 3, 2011 | 11:23 AM
martysmartie
Thats good then, don't suppose you know the percentage there uprated do you?
Martin
Old Apr 3, 2011 | 11:33 AM
peteh's Avatar
peteh
not a clue mate, expect that would be tip top secret info! lol
Old Apr 3, 2011 | 03:28 PM
peteh's Avatar
peteh
come on then, any tricks to get the bottom of the suspension leg out the hub......?
Old Apr 3, 2011 | 04:04 PM
martysmartie
Lol you need to lever the legs apart, Haynes suggest a cold chisel but if not a large screwdriver etc...
Martin
Nov 1, 2015 06:53 PM
3drRich
Sep 13, 2015 07:32 PM
truffleshuffle
Sep 10, 2015 09:35 PM
turbotrev
14
Sep 6, 2015 10:27 AM
cromb2555
Sep 3, 2015 04:28 PM
