2002 Ford OBDII questions
Old Nov 8, 2010 | 03:18 PM
Gazdaman's Avatar
Gazdaman
Default 2002 Ford OBDII questions
Hi guys,
I've got a 2002 Mondeo TDCI that's starting to have a few issues. I've got an OBDII scanner, but it doesn't appear to be compatible with the car, from reading up it looks like pre 2004 it didn't support OBDII. (Either that, or my cheapy OBD reader has given up the ghost)
So what standard does it use? Because the socket's there under the steering wheel.
I just want to read off any ECU error codes that might be present. More than happy to use laptop based cable and software.
Gaz
Old Nov 8, 2010 | 06:04 PM
oldford's Avatar
oldford
Petrol cars must have this socket as required by law.
Diesel passenger cars are not required to have it until 2004. For diesel commercial vans (like the Transit) it's 2007.
It's there because that is easier and cheaper for Ford to manufacture.
Communication protocol is Ford company protocol.
And No, your obd2 scanner won't work on it.
By the way, obd2 is something that exists in the USA and Canada only. It has no meaning in Europe and no car here (except imported cars from the USA) will comply with obd2 rules. Over here we have EOBD, which is very similar to obd2, but in some key areas it differs - like the starting date and when to set a diagnostic trouble code.
Old Nov 8, 2010 | 09:27 PM
Gazdaman's Avatar
Gazdaman
Thanks for that, I had read that it was 2004 for Diesel cars, I just find it strange that my car has the correct socket, in the place that complies with EOBD regulations (within 18" of the steering wheel).
So what sort of equipment do I need, or what protocol do I need to use to read any error code from my pre-EOBD Mondeo?
Gaz
Old Nov 8, 2010 | 09:35 PM
dojj's Avatar
dojj
Resident Wrestling Legend
you need a obd scanner, not an obd 1 scanner to see if that works
find someone who has one you can try out before you buy something
Old Nov 9, 2010 | 07:26 AM
oldford's Avatar
oldford
The correct socket is not strange, it's good thinking by Ford. When you buy something in bulk it's cheaper - that's why this socket is in every Ford.
The second advantage is that they only have to make 1 cable for their own diagnostic machines. Cheaper again.
Have a look here: http://www.autoenginuity.com/product...ware.html#EI01
That claims to have support for Mondeo TDCI's.
Old Oct 4, 2012 | 07:34 PM
deathrider666's Avatar
deathrider666
Damn Cars
Where does it actually say on the car wether it's obd or eobd?
Old Oct 4, 2012 | 07:36 PM
deathrider666
Damn Cars
If my car isn't obd, which I don't think it is (Mondeo tdci 2002) what is it?
Old Oct 5, 2012 | 06:59 AM
oldford's Avatar
oldford
Oh, but it does have OBD.
OBD is a general term which means: On-board Diagnostic.
Nothing is regulated by law and every manufacturer is free to choose his own method.
Even the first Cosworth's already had OBD. Granted, just a flashing led, but it still is On-board Diagnostics.
Another Ford scanner: http://www.forscan.org/
Old Oct 5, 2012 | 07:07 AM
RichieST's Avatar
RichieST
My 2001 diesel mondeo has got the socket, the software I use for it is called F-Super, you can get it on ebay. You can program injectors with it and I think it costs around £15, bargain!
Old Jun 4, 2016 | 07:19 PM
mattypompy's Avatar
mattypompy
Hi RichieST. I have a Focus 02 tdci and have had no joy with elm adaptors. Can you tell me what software you use? I have an android platform and was thinking of Forscan and buying the F Super adaptor? Been pulling my hair out!
Thanks
Anutternutter
24
Aug 31, 2015 01:24 PM
borboyous
Aug 22, 2015 11:17 AM
Caddyshack
Aug 19, 2015 07:29 PM
A.t.p
Aug 15, 2015 11:37 AM
