ERST ACT's??
What do peoples ACT guages read?
The reason i ask is since i have rebuit me engine (to the same spec it was before) my ACT readings have increased. Before the rebuild i would normally get a maximum of 30deg when on boost for long periods on the motorway. Now when i come on boost the ACT readings increase very quickly and are soon in the high 40s
The only thing i have done is to relocate the charge cooler reservoir to near the air filter as i fitted a strut brace (see pic).....
This ment shortning the feed and return pipes to the reservoir therefore slightly reducing the water capacity of the system.
I am using a R&B Motorsport ACT guage and a Pace charge cooler.
Any ideas?
Any ideas?
Any ideas?
Any ideas?
Yeh the pump is working, if i remove the top off the reservoir you can see water entering from the return hose.
All i have done is relocated the reservoir, the hoses are connected up in exactly the same way, just a bit shorter.
Im runnin out of ideas as well
I do have the grey pump ant it was difficult to bleed. The system has been installed with flexible transparent hoses and i can see there are no air bubbles in the system, as i say the water seems to be circulating ok.
DixieTheKid
11
Jun 6, 2020 11:20 AM
Mc5506
Oct 5, 2015 09:57 PM
