4x4 engine looms
Old Jul 3, 2009 | 08:48 PM
hughy's Avatar
hughy
Default 4x4 engine looms
what wire's need to be connected up to a 4x4 engine loom as my ecos was a small turbo to start with? cheers hugh
Old Jul 3, 2009 | 09:41 PM
costina's Avatar
costina
Live long and prosper!!
get yourself a 2wd loom then you don't have to mess around with the escorts troublesome fuse box as they have the eng management and fuel pump relays on the loom
from memory for the 2wd loom
black ignition live
green tacho
black red trace fuel pump +
red batt +
brown white trace temp gauge
earths are bolted to the intake manifold
tbh this is the easiest way to go as anyone with a escos will tell you the eng looms are a pain
hope this helps you a bit
Paul
Old Jul 4, 2009 | 06:57 PM
andy130's Avatar
andy130
black ignition live
green tacho
red batt +
Paul
cheers paul, have 2wd loom coming now, cheers hugh
big_Rad
Sep 15, 2017 09:36 AM
kosienutter
31
Aug 22, 2015 09:55 AM
Topjoe9
Aug 20, 2015 02:38 PM
muz
Aug 16, 2015 12:57 PM
Roosie
Aug 15, 2015 08:09 PM
