Oil in boost pipes?
Old Feb 25, 2009 | 05:41 PM
kidsRS's Avatar
kidsRS
"Ill check the stock"
Default Oil in boost pipes?
Stripped the gearbox out of my s1 today to find oil in my bottom boost hoses the engine is a freshly built zvh with a stage 3 technics turbo the lot has only done 1600 miles and hasnt been on the road since last november? I know it sounds like the turbo but its only done 1600 steady miles.
Any ideas?
Old Feb 25, 2009 | 06:15 PM
boothy's Avatar
boothy
you have filled your intercooler up with oil
Old Feb 25, 2009 | 06:28 PM
kidsRS's Avatar
kidsRS
Its done that itself by the looks of it! not ammused!
Old Feb 25, 2009 | 06:54 PM
boothy's Avatar
boothy
, spoke to a mate he said maybe turbo or headgasket ??
Old Feb 25, 2009 | 07:05 PM
Childsyxxx's Avatar
Childsyxxx
Would get oil from the headgasket youd get water so you can rule that out me thinks
Old Feb 25, 2009 | 07:27 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah defo not HG!
If your still on MFI did you clean out the metering head,all breather pipes, and breather filter? There is generally plenty of oil floating around in them after 20 years of driving
Also if your IC is not new that will have oil in it from the previous engine.
Old Feb 25, 2009 | 07:51 PM
boothy's Avatar
boothy
its a new cooler mate..
Old Feb 25, 2009 | 08:00 PM
B16CVH's Avatar
B16CVH
How much oil we talkin??
Old Feb 25, 2009 | 08:03 PM
boothy's Avatar
boothy
about a quarter of a cup mate,,,
Old Feb 25, 2009 | 08:07 PM
taz1787's Avatar
taz1787
Escort Cabriolet Owner
if its a lot of oil then clean it run it and then check again if its full again then its the turbo mate
Old Feb 25, 2009 | 08:10 PM
boothy's Avatar
boothy
not good its a new blower
Old Feb 25, 2009 | 08:30 PM
B16CVH's Avatar
B16CVH
Either blower or you engine is breathing heavy or overfilled with oil.
Old Feb 25, 2009 | 09:00 PM
boothy's Avatar
boothy
well now you say that he said that he had the wrong dip stick so hes changed that so thats maybe his problem...
Old Feb 25, 2009 | 09:05 PM
B16CVH's Avatar
B16CVH
Are you pondering what im pondering pinky.............
Old Feb 25, 2009 | 09:10 PM
boothy's Avatar
boothy
yes think thats his problem.... clive drain some oil out mate..... put that bong down first
Old Feb 25, 2009 | 09:20 PM
Smartdj.'s Avatar
Smartdj.
when i had a fire in my engine bay i used my washing up bowl to put it out....after i replace all my fuel lines and what not i tryed to fire it up ..it did after a while but really lumpy and i couldnt work out why intill i took my bottom boost gauge off and found half a spagbol in there ..pasta and all sorts..lol had to replace everything lol
Old Feb 26, 2009 | 11:44 AM
kidsRS's Avatar
kidsRS
When i built it everything was spotless and new breather system and pipes etc.
And yes i think iv been over filling it with oil ill clean eveything immensly and see what happens!!
Old Feb 26, 2009 | 12:20 PM
boothy's Avatar
boothy
good stuff, may have you a little job mate..... brookes needs new battery tray annd some bulkhead welding in the XR if your interested.... told him about the welding your doing on the s2 and think he would like you to do it
Old Feb 26, 2009 | 12:41 PM
kidsRS's Avatar
kidsRS
yes im interested tell him
Old Feb 26, 2009 | 03:35 PM
boothy's Avatar
boothy
how much labour, hes got the pannels.....
Rich Coveney
Ford Mondeo Including ST
Sep 15, 2015 05:39 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
