VNC software (like PC anywhere) `
Old Nov 25, 2004 | 04:53 PM
BigNige's Avatar
BigNige
Default VNC software (like PC anywhere) `
As above really
What a TOP bit of kit
I have downloaded it for my PC and Laptop and set it up so i can now watch from downstairs EVERY thing that Josh does on the desktop in the office upstairs and CONTROL Is PC
NOow that is the bollox
www.vnc.com the only thing i had to do was
1. Know the IP addys of the 2 machines wooooo hooo
2. Allow it access through the firewall
Now that is clever bit of kit and FREEEEEE
nige
Old Nov 25, 2004 | 04:55 PM
Spiky's Avatar
Spiky
installed vnc client on machine
and use ultravnc to connect, it's much faster
Old Nov 25, 2004 | 06:09 PM
RS_Series2's Avatar
RS_Series2
We use VNC at my work to connect to 100's of machines of our network, think that we might well have the licences for it though!!!
Good piece of software when it doesnt play up and as long as you dont try to install it on a 95 machine
Old Nov 25, 2004 | 06:23 PM
Dave Henshall's Avatar
Dave Henshall
who knows if you can connect cross platform to a unix station through windows using it rather than using a graphical terminal emulator like Reflection X ?
assuming both machines reside on the same hub.
Old Nov 25, 2004 | 06:36 PM
Stu.H's Avatar
Stu.H
install a trojan
much easier
Old Nov 25, 2004 | 06:39 PM
Adrian's Avatar
Adrian
TightVNC for me.
Strips out the wallpaper
Old Nov 25, 2004 | 06:49 PM
Ratty's Avatar
Ratty
It works cross platform, but on some linux distros you need to start a x session after connecting to the vnc server
Old Nov 25, 2004 | 06:54 PM
Dave Henshall
does vnc support X sessions, or do you still need the emulator?
Old Nov 25, 2004 | 06:58 PM
Ratty's Avatar
Ratty
It use its own X server and runs application is that session
http://www.uk.research.att.com/archive/vnc/xvnc.html
Old Nov 25, 2004 | 07:01 PM
Dave Henshall
ah, excellent. could come in very usefull, saves buying licences for reflection x anyway.
off the top of you rhead... can it force a static (predetirmined) IP address to a Xwindow regardless of the machine IP address?
Old Nov 25, 2004 | 07:17 PM
Ratty's Avatar
Ratty
Not sure never tried it
Old Nov 25, 2004 | 08:21 PM
saff_cossie's Avatar
saff_cossie
I use this for work so I can access all the sites. Great bit of kit but we do have to pay for ours!
Andreas's Avatar
Andreas
I use it for my server in the kitchen, haven't got a monitor for it so its great to control from the other computer.
I also use it on my parents computer so I can help them out whenever they need some support. Perhaps not the safest way but it only runs when they need help and the firewall is shut otherwise as well plus its set to accept only my IP. So for the short periods I use I doubt would cause any harm.
Old Nov 25, 2004 | 10:33 PM
Jim Galbally's Avatar
Jim Galbally
dave, i think youre missing the whole point of Xwindows... lol whilst its handy to just get a screen up of another machine, the functionality of just running X proggys on a windows based Xserver (like for example Xwin32) beats it hands down if youre doing proper cross planform *nix stuff...
Old Nov 26, 2004 | 07:44 AM
Dave Henshall
so its not as good as reflection X say for example for running unix "terminals" on windows machines connecting to a unix host?
the problem we have is that our network dynamically assigns IP address on the fly, where the unix server needs the IP address to remain static to recocnise it as a terminal through Xwindows.
Old Nov 26, 2004 | 08:05 AM
SeanT's Avatar
SeanT
Our IT guys at work would have tired legs without VNC! Didn't realise it was free, time to install it on my home machine so I can listen to my music at work! (and access my porn )
Old Nov 26, 2004 | 08:06 AM
Jim Galbally
didnt know VNC did streming sound?
but then ive never installed it ona PC with a soundcard... lol
Old Nov 26, 2004 | 08:10 AM
SeanT's Avatar
SeanT
Hmmm, maybe I'm confused with Remote Desktop....
Old Nov 26, 2004 | 08:16 AM
SapphyMike's Avatar
SapphyMike
Been using VNC (Tridia and Ultra) for years... dont use it much now like, we use Citrix alot...
Old Nov 26, 2004 | 05:26 PM
Ratty's Avatar
Ratty
The unix box just needs to do a reverse lookup of the client IP, configure your dns server to add a reverse lookup zone for your network and it'll work fine using host name resolution
Old Nov 26, 2004 | 06:35 PM
MAD ANDY's Avatar
MAD ANDY
Dave
just get yourself an F5 Firepass SSL box or Checkpoint Connectra SSL and use the unix webification option
Old Nov 26, 2004 | 07:55 PM
Dave Henshall
so would the unix servers (that sit on their own hub on the lan) be web hosted through that box of tricks andy?
Old Nov 26, 2004 | 08:08 PM
Dave Henshall
trouble is the application we are running under unix only allows IP addresses, not DNS. we are due to upgrade the OS any time soon, cant remember what version of unix we are wunning at the moment, but does the lastest version allow DNS lookup?
Old Nov 26, 2004 | 08:10 PM
Ratty's Avatar
Ratty
I thought all used dns and reverse lookups, name resolution will fail though if you dont have a reverse lookup zone
Old Nov 26, 2004 | 08:24 PM
Dave Henshall
but this would need a list of every address that the hosts could ever be, our lan dynamically assigns ip addresses which expire after each logon, so the wya we get round it is to have the network reserve the ip address of the machine we need it on when it sees the mac address of the network card sigh o the system, these reserved addresses are soley for the machines we use reflectionx on .
if we could run reflectionx on any pc with any ipaddress and the unix servers still see them as terminals we'd be laughing, there must be more than one way of skinning a cat as they say.
Old Nov 26, 2004 | 08:27 PM
Ratty's Avatar
Ratty
The dhcp server updates the ptr records in the reverse lookup zone, its all dynamic
Old Nov 27, 2004 | 06:30 PM
MAD ANDY's Avatar
MAD ANDY
not web hosted no and not needing to sit on a DMZ either, just the SSL box will make a connection to the UNIX box and 'webify' it so that you can see it within a browser where ever you may be ie corporate laptop internally, externally, or a PDA over GPRS or even a webcafe etc!
jay030787
Sep 25, 2015 01:38 AM
apples24
14
Sep 20, 2004 02:50 PM
Computers, Consoles and I.T.
Jan 26, 2004 03:02 PM
