shocks and springs
Old Jul 18, 2008 | 10:05 AM
YBT200's Avatar
YBT200
Default shocks and springs
hi there, what shocks and springs do you prefer on an escort cosworth for both handling and look , because i am very confused what to do?
Old Jul 18, 2008 | 01:29 PM
ECOS95's Avatar
ECOS95
Ahmed springs, Koni dampers.
Old Jul 18, 2008 | 01:50 PM
Kelv's Avatar
Kelv
Almost there!
as the man said above
the best bet for all round use - unless your happy to start spending silly money on decent coilover setups.
Old Jul 18, 2008 | 06:28 PM
ECOS95's Avatar
ECOS95
Can't take all the credit, took advice from people on here & Mike R.
Very pleased with the ride & stance of it now.
Old Jul 18, 2008 | 07:37 PM
YBT200's Avatar
YBT200
i was told to use gaz adjustable shocks with gaz springs ,what do you think of them?are they good?
Old Jul 18, 2008 | 07:41 PM
ECOS95's Avatar
ECOS95
There's a thread in GD currently about Coil overs etc. Worth a read.
Old Jul 18, 2008 | 07:45 PM
Kelv's Avatar
Kelv
Almost there!
Told by who?
i wouldnt spend £500 on Gaz coilovers id rather spend £500 on Koni's and Ahmed springs.
Old Jul 21, 2008 | 08:11 PM
YBT200's Avatar
YBT200
anyone knows how much the ahmed bayoo springs will lower the car, because i am looking to lower it about 30mm range ?
Old Jul 21, 2008 | 08:24 PM
KSA-Cossie's Avatar
KSA-Cossie
Around -20 mm m8.
Old Jul 22, 2008 | 07:40 AM
YBT200's Avatar
YBT200
what about the gaz adjustable shocks with their springs (not the coilovers ones ) , have someone used them , what do you think about them? are they good quality? i've heard that these lower the car by 30mm.
Old Jul 22, 2008 | 08:43 AM
ECOS95's Avatar
ECOS95
Here's a picture of mine with Koni's & ahmed springs that I bought from Mike R.
Old Jul 30, 2008 | 01:33 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Looks perfect !
Old Jul 30, 2008 | 05:29 PM
ECOS95's Avatar
ECOS95
Looks perfect !
& no problems with speed bumps either (Splitter still on & intact) Just need to buy a nice carbon set.
Old Jul 30, 2008 | 08:13 PM
YBT200's Avatar
YBT200
do you know how much it will be lowered with them?
Old Jul 30, 2008 | 08:27 PM
YBT200's Avatar
YBT200
and what about the handling ?
Old Jul 30, 2008 | 08:57 PM
ECOS95's Avatar
ECOS95
25mm roughly, I've got a picture before the kit was put on somewhere.
Old Jul 30, 2008 | 09:00 PM
ECOS95's Avatar
ECOS95
Good for road use in the UK, the roads round here are rubbish.I've got the fast road springs & the Koni's on full soft front & rear & its still a big improvement over standard. Oh & the front end is fully Poly bushed.
Never been in a car with Coilovers so can't compare.
Old Jul 31, 2008 | 12:03 PM
Mike Rainbird
Caraholic
Very good!
Old Nov 28, 2008 | 06:04 PM
cossytonyt's Avatar
cossytonyt
how much are the springs
Old Nov 28, 2008 | 06:13 PM
Mike Rainbird
Caraholic
£170 delivered .
Old Nov 30, 2008 | 09:33 PM
booner999's Avatar
booner999
just bought the ahmed and konis. Mike and co all rated them very highly
Old Nov 30, 2008 | 10:34 PM
Kelv's Avatar
Kelv
Almost there!
Old Dec 1, 2008 | 02:36 PM
Clikettman's Avatar
Clikettman
And what do you think about Bilstein shocks ?
They are not so expensive and I think they have a far better quality and damping results than Konis...
On my Escort I have Kayabas Ultra SR shocks, even these ones are better than Koni I think.
Old Dec 1, 2008 | 05:54 PM
Mr.Ford's Avatar
Mr.Ford
I have a Wolf suspension kit (Bilstein shocks and Eibach springs). The ride is superb!
Better than the Koni / Apex setup I used to have on my previous one
Old Dec 2, 2008 | 08:37 AM
Mike Rainbird
Caraholic
I don't rate Bilsteins, as they are not adjustable.
The problem is matching the Konis with springs that do not suit it's damping rates. When you do do this, the transformation is unbelievable compared to cheap springs....
Old Dec 3, 2008 | 11:37 AM
SO COSSIE's Avatar
SO COSSIE
Were is the best place to get the ahmed springs from.
Also how much am i looking at for an escort cosworth
Old Dec 3, 2008 | 11:59 AM
SO COSSIE's Avatar
SO COSSIE
Sorry just seen your add £170
also is it true you need to cut the spring platform on the koni shocks to get them to miss the tyre on a escort cosworth
Old Dec 3, 2008 | 12:25 PM
Mike Rainbird
Caraholic
Depends what wheel (offset) you have . Fitting Compomotives in 8x18, ET15 will negate this. However, if you have wheels with the original ET25 offset, then you will need to tweek the spring platform with a hammer like this:
Old Dec 3, 2008 | 02:21 PM
SO COSSIE's Avatar
SO COSSIE
My old wheels were 8 18 e/t 25 but now i have 8 18 e/t 15.They have allways missed the wheel but the spring platform is above the tyre and the car seems to seat high its on koni shoks with graham/g springs and koni rear springs. does this seem odd as its doing my head in why it sits so high
Do you think i should change the springs to ahmed spring or change the lot some think must be wrong
Old Dec 3, 2008 | 07:34 PM
Dave Henshall's Avatar
Dave Henshall
you've also got to watch if lowering it too much (more than 20mm) that your egine mounts are in tip top shape - as the more yuo lower the more you increase the angle of the driveshafts from the front dif to the hubs and they can easilly pop out when you accellerate if the engine mounts are getting a bot long in the tooth, swap them for a new set of ford ones for comfort - at a set of vibratech ones for fit and forget but they do introduce a bit of vibration into the cabin.
Old Dec 4, 2008 | 08:13 AM
Mike Rainbird
Caraholic
Lets see some pictures of your idea of "high". "Slamming an Escort into the weeds" will copletely screw the ride and handling. The GGR springs usually sit the car nicely IMO and are not too low to cause any handling / reliability woes.
Old Dec 4, 2008 | 06:37 PM
SO COSSIE's Avatar
SO COSSIE
Sorry about the picks
Old Dec 4, 2008 | 07:33 PM
booner999's Avatar
booner999
thats fine above, anymore and it wont look right if you ask me
Old Dec 4, 2008 | 08:05 PM
SO COSSIE's Avatar
SO COSSIE
Not looking to have it on the floor but would be nice to have the wheels closer to the arches.
Old Dec 5, 2008 | 07:34 AM
Mike Rainbird
Caraholic
If you lower it any more, it will fuck up the handling and cause front drive shaft failure if the car has any power .
Mine is on coilovers and is not much different to yours!
Old Dec 5, 2008 | 08:02 AM
SO COSSIE's Avatar
SO COSSIE
easy way out of it then is to get a fat bird and seat it in the back with her head down
Thanks. i may think about new springs just for the back end as the fat bird will eat more than the car on supper unleadded.
Old Dec 5, 2008 | 08:35 AM
Mike Rainbird
Caraholic
I personally would not mix and match spring types...
Old Dec 5, 2008 | 12:57 PM
SO COSSIE's Avatar
SO COSSIE
You best have a sale on after chrstmas then 50% off ahmed springs top man
Nov 1, 2015 06:53 PM
Rod-Tarry
75
Oct 13, 2015 04:44 PM
SMILER258
Sep 28, 2015 09:04 AM
Topjoe9
Sep 12, 2015 09:50 AM
