shocks and springs
Old 18-07-2008, 10:05 AM
YBT200
YBT200's Avatar
Default shocks and springs
hi there, what shocks and springs do you prefer on an escort cosworth for both handling and look , because i am very confused what to do?
Old 18-07-2008, 01:29 PM
ECOS95
ECOS95's Avatar
Ahmed springs, Koni dampers.
Old 18-07-2008, 01:50 PM
Kelv
Almost there!
Kelv's Avatar
as the man said above
the best bet for all round use - unless your happy to start spending silly money on decent coilover setups.
Old 18-07-2008, 06:28 PM
ECOS95
ECOS95's Avatar
Can't take all the credit, took advice from people on here & Mike R.
Very pleased with the ride & stance of it now.
Old 18-07-2008, 07:37 PM
YBT200
YBT200's Avatar
i was told to use gaz adjustable shocks with gaz springs ,what do you think of them?are they good?
Old 18-07-2008, 07:41 PM
ECOS95
ECOS95's Avatar
There's a thread in GD currently about Coil overs etc. Worth a read.
Old 18-07-2008, 07:45 PM
Kelv
Almost there!
Kelv's Avatar
Told by who?
i wouldnt spend £500 on Gaz coilovers id rather spend £500 on Koni's and Ahmed springs.
Old 21-07-2008, 08:11 PM
YBT200
YBT200's Avatar
anyone knows how much the ahmed bayoo springs will lower the car, because i am looking to lower it about 30mm range ?
Old 21-07-2008, 08:24 PM
KSA-Cossie
KSA-Cossie's Avatar
Around -20 mm m8.
Old 22-07-2008, 07:40 AM
YBT200
YBT200's Avatar
what about the gaz adjustable shocks with their springs (not the coilovers ones ) , have someone used them , what do you think about them? are they good quality? i've heard that these lower the car by 30mm.
Old 22-07-2008, 08:43 AM
ECOS95
ECOS95's Avatar
Here's a picture of mine with Koni's & ahmed springs that I bought from Mike R.
Old 30-07-2008, 01:33 PM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
Looks perfect !
Old 30-07-2008, 05:29 PM
ECOS95
ECOS95's Avatar
Looks perfect !
& no problems with speed bumps either (Splitter still on & intact) Just need to buy a nice carbon set.
Old 30-07-2008, 08:13 PM
YBT200
YBT200's Avatar
do you know how much it will be lowered with them?
Old 30-07-2008, 08:27 PM
YBT200
YBT200's Avatar
and what about the handling ?
Old 30-07-2008, 08:57 PM
ECOS95
ECOS95's Avatar
25mm roughly, I've got a picture before the kit was put on somewhere.
Old 30-07-2008, 09:00 PM
ECOS95
ECOS95's Avatar
Good for road use in the UK, the roads round here are rubbish.I've got the fast road springs & the Koni's on full soft front & rear & its still a big improvement over standard. Oh & the front end is fully Poly bushed.
Never been in a car with Coilovers so can't compare.
Old 31-07-2008, 12:03 PM
Mike Rainbird
Caraholic
Very good!
Old 28-11-2008, 06:04 PM
cossytonyt
cossytonyt's Avatar
how much are the springs
Old 28-11-2008, 06:13 PM
Mike Rainbird
Caraholic
£170 delivered .
Old 30-11-2008, 09:33 PM
booner999
booner999's Avatar
just bought the ahmed and konis. Mike and co all rated them very highly
Old 30-11-2008, 10:34 PM
Kelv
Almost there!
Kelv's Avatar
Old 01-12-2008, 02:36 PM
Clikettman
Clikettman's Avatar
And what do you think about Bilstein shocks ?
They are not so expensive and I think they have a far better quality and damping results than Konis...
On my Escort I have Kayabas Ultra SR shocks, even these ones are better than Koni I think.
Old 01-12-2008, 05:54 PM
Mr.Ford
Mr.Ford's Avatar
I have a Wolf suspension kit (Bilstein shocks and Eibach springs). The ride is superb!
Better than the Koni / Apex setup I used to have on my previous one
Old 02-12-2008, 08:37 AM
Mike Rainbird
Caraholic
I don't rate Bilsteins, as they are not adjustable.
The problem is matching the Konis with springs that do not suit it's damping rates. When you do do this, the transformation is unbelievable compared to cheap springs....
Old 03-12-2008, 11:37 AM
SO COSSIE
SO COSSIE's Avatar
Were is the best place to get the ahmed springs from.
Also how much am i looking at for an escort cosworth
Old 03-12-2008, 11:59 AM
SO COSSIE
SO COSSIE's Avatar
Sorry just seen your add £170
also is it true you need to cut the spring platform on the koni shocks to get them to miss the tyre on a escort cosworth
Old 03-12-2008, 12:25 PM
Mike Rainbird
Caraholic
Depends what wheel (offset) you have . Fitting Compomotives in 8x18, ET15 will negate this. However, if you have wheels with the original ET25 offset, then you will need to tweek the spring platform with a hammer like this:
Old 03-12-2008, 02:21 PM
SO COSSIE
SO COSSIE's Avatar
My old wheels were 8 18 e/t 25 but now i have 8 18 e/t 15.They have allways missed the wheel but the spring platform is above the tyre and the car seems to seat high its on koni shoks with graham/g springs and koni rear springs. does this seem odd as its doing my head in why it sits so high
Do you think i should change the springs to ahmed spring or change the lot some think must be wrong
Old 03-12-2008, 07:34 PM
Dave Henshall
Dave Henshall's Avatar
you've also got to watch if lowering it too much (more than 20mm) that your egine mounts are in tip top shape - as the more yuo lower the more you increase the angle of the driveshafts from the front dif to the hubs and they can easilly pop out when you accellerate if the engine mounts are getting a bot long in the tooth, swap them for a new set of ford ones for comfort - at a set of vibratech ones for fit and forget but they do introduce a bit of vibration into the cabin.
Old 04-12-2008, 08:13 AM
Mike Rainbird
Caraholic
Lets see some pictures of your idea of "high". "Slamming an Escort into the weeds" will copletely screw the ride and handling. The GGR springs usually sit the car nicely IMO and are not too low to cause any handling / reliability woes.
Old 04-12-2008, 06:37 PM
SO COSSIE
SO COSSIE's Avatar
Sorry about the picks
Old 04-12-2008, 07:33 PM
booner999
booner999's Avatar
thats fine above, anymore and it wont look right if you ask me
Old 04-12-2008, 08:05 PM
SO COSSIE
SO COSSIE's Avatar
Not looking to have it on the floor but would be nice to have the wheels closer to the arches.
Old 05-12-2008, 07:34 AM
Mike Rainbird
Caraholic
If you lower it any more, it will fuck up the handling and cause front drive shaft failure if the car has any power .
Mine is on coilovers and is not much different to yours!
Old 05-12-2008, 08:02 AM
SO COSSIE
SO COSSIE's Avatar
easy way out of it then is to get a fat bird and seat it in the back with her head down
Thanks. i may think about new springs just for the back end as the fat bird will eat more than the car on supper unleadded.
Old 05-12-2008, 08:35 AM
Mike Rainbird
Caraholic
I personally would not mix and match spring types...
Old 05-12-2008, 12:57 PM
SO COSSIE
SO COSSIE's Avatar
You best have a sale on after chrstmas then 50% off ahmed springs top man
01-11-2015 06:53 PM
Rod-Tarry
75
13-10-2015 04:44 PM
SMILER258
28-09-2015 09:04 AM
Topjoe9
12-09-2015 09:50 AM
Quick Reply: shocks and springs
