Gearbox for 2.1 Zetec Turbo
Old Feb 20, 2008 | 04:05 PM
Zetechamo's Avatar
Zetechamo
Default Gearbox for 2.1 Zetec Turbo
I am currently restoring an RS turbo S2, I am going to put a 2.1 Zetec Turbo engine in which will give about 250 bhp. The engine and gearbox configuration will remain transverse. Can anyone suggest which gearbox would be suitable I want one with an LSD in it.
Old Feb 20, 2008 | 09:46 PM
Phil2002's Avatar
Phil2002
standard rst one will bolt to a zetec no probs just put a uprated clutch in it.
Not sur how long it will last depends on how you drive it. You can put an ib5 box in it(with a bit of work) which is a bit stronger than the rst bc one and you can put a rst lsd in it. Or for loads of work put a mt75 box in.
Hope this helps.
Old Feb 21, 2008 | 12:47 PM
Maki's Avatar
Maki
IB5 and BC boxes are the same, only starter location is different... I don't see why it should be any stronger.
If you go for RST BC box, you'll have to use CVH EFI flywheel with enlarged bolt holes or 1.8/1.6 zetec flywheel as the 2.0 mondeo one will not fit.
Old Feb 21, 2008 | 05:25 PM
woolford's Avatar
woolford
put an mtx75 box in with a spec 3 clutch and a quaife diff problem solved and there very
Old Feb 22, 2008 | 01:02 PM
Maki's Avatar
Maki
People in my neighbourhood keep on braking those MTX boxes on their standard RS2000, so how can it hold more on 2.1 ZVH???
Old Feb 22, 2008 | 01:10 PM
FULLBORE's Avatar
FULLBORE
mtx boxes will take pretty much anything you can throw at them mate...
Old Feb 22, 2008 | 01:59 PM
Luca's Avatar
Luca
Lukesville
By a gearboxman stage 2+ quaife diff with that and sorted for that power
300 + then look at focus rs or st170 box options
Old Feb 22, 2008 | 09:42 PM
woolford's Avatar
woolford
Thumbs up
i didnt mean the one on the rs2000 the one of the focus cant remember without looking but in performance ford recently some guy hamered an mtx in a series one with over 300bhp and couldn't brake it and that didnt even have a wuaife diff in so they are very strong!!
Old Feb 23, 2008 | 10:41 AM
Maki's Avatar
Maki
So you say focus MTX difers from escort MTX (that was in XR3 and RS2000)?
Old Feb 23, 2008 | 11:28 PM
wul young's Avatar
wul young
mtx is the only way forward,or 6 speed st170 box,had my mtx,with quaife atb in for approx 2500mls and beleive me it aint had an easy life,i put a standard mtx in as a test subject to start with,thats as they come no mods whatsoever,i abused it for over 1000mls and try i may,i could not brake it,good goin considering i had done 9 ib5 boxes in under 10 months.
Old Feb 24, 2008 | 10:21 AM
2ndGear's Avatar
2ndGear
A LITTLE KNOWLEDGE IS DANGEROUS. IT GET REALLY PI$*ED OFF WHEN PEOPLE THINK THEY KNOW ABOUT GEARBOXES. IB5 & BC BOXES ARE DIFFERENT INTERNALLY.
Old Feb 24, 2008 | 12:11 PM
Maki's Avatar
Maki
Any proof?
Old Feb 24, 2008 | 12:49 PM
JesseT's Avatar
JesseT
Any proof?
A few of the bearings are larger in size, the gears are slightly wider, and the syncros are better on the first few gears. Casings are ribbed too for less flex.
Old Feb 24, 2008 | 01:16 PM
Maki's Avatar
Maki
Good info... you shouldn't believe everything you read on the net. As the fact that IB5 and BC are the seme I read there. Anyway reading what Wul Young says that doesn't help the IB5 to be stronger.
Now question to Wul what car did you take your MTX off that worked for you? as you see some say that focus ones are different from escort ones.
Old Feb 24, 2008 | 11:06 PM
wul young's Avatar
wul young
Thumbs up
hi m8,focus ones mount differently for start,and have cable,not all of them though,this is easily changed though as both gearsets are exacly tha same,the difference is coice of three different final drives,as i found out by stupidly fitting a 4.1 final drive instead of the 3.8 i have been using and was used to,back to 3.8 now though.but i would say driveshaft setup is a big part to play,equal length is night and day in my car,tried both ways over winter,just to know for myself and anybody that wants my opinion if all these theries and old wifes tales were true,as i say thats my opinion and it works very well for me,oh and geometry is key facter to.
Old Feb 25, 2008 | 07:55 PM
Phil2002's Avatar
Phil2002
Smile
Thanks 2ndGear i love being right.
JoeyBoyden
Jan 4, 2024 02:36 PM
robnock
21
May 13, 2019 05:29 PM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
Cameron
14
Aug 9, 2015 06:28 AM
