3dr cosworth rear polybushes
hi can any one tell me if poly bushing the rear of a 3dr cossie for road use is a good idea or not as i have been told they can make the rear end skittish because they are so stiff, any info would be appreciated thanks
The geometry is a joke on sierras anyway so can't get any worse!!
It will make it more DIRECT, but some can bring HORRENDOUS vibration, as I found out, when I fitted SUPERFLEX here, (though they were ok everywhere else).
Saying that I have Deflex on my sapphy and they are ace, but still going back to std bushes with axle tightening kit(GGR) more expensive but I like it a lot better.
The TOE corrector shims will improve it big time, for so little outlay, £10 from R&B MOTORSPORT, this will make it more skittish as some call it, it just becomes a lot more responsive, and stops the dreaded inner tyre wear at the rear.
Regards
Dave
JoeyBoyden
04-01-2024 02:36 PM
09-10-2015 07:38 PM
