excessive toe out?
Old Feb 10, 2007 | 07:05 PM
shanemc's Avatar
shanemc
Default excessive toe out?
just looked at the front wheels om my saff cossie today,there seems to be a lot of toe out,probably nearly an inch,would this cause the steering turn in to be very slow and vauge?the steering has gone very vauge,turn in is v.bad,takes near a third of a turn to get the car to turn in quickly.ill be getting it tracked during the week,just wondering would the toe out cause this?
thanks,
Shane
Old Feb 10, 2007 | 07:11 PM
DazC's Avatar
DazC
Toe out usually makes a car more nervous.
The only way to know is to get the geometry checked. A tyre exhaust place will be able to set your tracking.
Old Feb 10, 2007 | 07:32 PM
shanemc's Avatar
shanemc
unfortunately its far from nervous,steering is very unresponsive.hopefully getting the tracking sorted will cure it,dont fancy having to go changing the rack etc if its worn
Old Feb 10, 2007 | 07:44 PM
slickescort1981's Avatar
slickescort1981
ur right it will be tracking as long as nothin has suddenly broken underneath, whoever aligns it should soon spot if it has. big toe in will make it very twitchy, and big toe out should cause ur syptoms. if its as bad as u say id be surprised if it registers on the guages before its adjusted. let us know how u get on.
Old Feb 11, 2007 | 07:17 AM
It would squirm like buggery if it really is 1" toe out, jesus that is a lot.
It will be all over the place, might be wise to check track rod ends and bottom arm joints first, if they are worn it will need doing after the repair, so save money and check/repair first.
Old Feb 11, 2007 | 04:16 PM
shanemc's Avatar
shanemc
took it out today down the road for a spin on the new wheels,it does wander an awful lot,very twitchy,but the actual turn-in is very unresponsive,ive tca poly bushes ordered,so itll be getting those,a new set of bridgestone 215/40/16's(cos the monte 225/45's are too big)and getting tracked in the next week or so,so hopefully that lot will improve it.ill keep ye posted anyway.cheers for all the advice
Old Apr 15, 2007 | 01:27 PM
shanemc's Avatar
shanemc
got the new tires and got the tracking set,steering has improved hugely,no twitching and the turn-in is nice and responsive.
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
Cos500
Sep 16, 2015 09:50 PM
Bailes1992
Sep 3, 2015 02:17 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Davemurphy007
Motorcycle Chat & Sales
Aug 14, 2015 05:58 PM
