boost problems! help?!
Old Feb 1, 2007 | 08:53 PM
kev_erst's Avatar
kev_erst
Default boost problems! help?!
i seem to be having a problem with my s2 boosting?!
the car is fine once in the norm on the temp gauge but when it reaches around half way thats when the problems start!
i feel the boost start to come in as normal but then i get alot of noise from the air filter and exhaust and i seem to have no power, if i ease off the pedal the go back on i seem to get the boost back but this doesnt always work?!
i hav recently been running a bailey dump valve and a pipercross filter, i have removed the dump valve but there seems to be no improvment.
i am yet to change the filter but could this causing the problem?!?!?!
please help
Old Feb 1, 2007 | 10:43 PM
Dragsteer's Avatar
Dragsteer
same problem as I have. Today I found (before 1 hour) that my cables of spark plugs have flashes, I mean cables need to be replace, maybe will be better.
do you have connected hose from fuel pressure regulator to crossover pipe (before throttle after intercooler) ?
p.s. dont change air filter- I try it but nothing. I think we have injector problems
Old Feb 2, 2007 | 12:42 AM
SafeChav's Avatar
SafeChav
This is a REALLY common thing with MFI mate.
Me personally i would recommend checking your TPS is working correctly, the one on my first RS was knackered and i experienced this hesitation, and seemed to cure when i replaced the switch.
The TPS is the sole component that triggers full load enrichment, if it fails the car runs lean!!
A set up probably wouldn't go a miss either!
Old Feb 2, 2007 | 12:15 PM
Dragsteer's Avatar
Dragsteer
good idea. my throttle position sensor does not click, is this possible reason?
Old Feb 2, 2007 | 12:47 PM
SafeChav's Avatar
SafeChav
I was actually replying to the person who started the thread i wouldn't know where to begin with your car, it seems like its got a few problems.
For info though it only clicks at the idle end, full throttle it won't click.
Old Feb 2, 2007 | 01:57 PM
Dragsteer's Avatar
Dragsteer
Thanks. my click only if I set idle too low ( about 500 rpm-impossible to idle)
Old Feb 2, 2007 | 01:58 PM
SafeChav's Avatar
SafeChav
DO NOT play with the throttle stop screw!
Old Feb 2, 2007 | 04:26 PM
Dragsteer's Avatar
Dragsteer
why?
Old Feb 2, 2007 | 04:42 PM
SafeChav's Avatar
SafeChav
Its not something that should ever need adjusting and by playing with that you are throwing out the TPS adjustment..........
JK12
33
Apr 26, 2021 12:09 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
