Really Bad Idle - 1.8 Zetec
Old Apr 4, 2006 | 10:05 AM
robbyridz's Avatar
robbyridz
Default Really Bad Idle - 1.8 Zetec
Hi There,
I have been having some problems recently with my 98 Escort 1.8 Si. The car was loosing a lot of power and idle was rough and cut out when engine was cold.
I took for an ECU scan which only uncovered an issue with AFM, I went to breakers and replaced this and all seemed well, idle improved a little and all my power has come back.
Day later... all my power is still there, however the idle has got worse - it will just keep cutting out all of the time if I'm at lights without foot on pedal. If I try and keep it around 1000-1500 with my foot it'll cough a bit, and then the revs will start climbing - it really fustrates me
Any ideas? Garage seem to think ICV looks new but it aint had one since I've owned it - and I got it at 78k and now it's done 87k.
I'm thinking about fitting a 2L throttlebody soon and some 2L cams and 130bhp ecu, is the ICV part of the throttlebody, and what pipework would I need to fit one with my existing airbox/ afm?
I would like to cure this problem really before having that lot fitted, would it be worth just getting a 1.8 throttlebody from breakers first (if ICV is part of it)
Any advice at all will be greatly appreciated - cheers
Old Apr 6, 2006 | 02:22 PM
robbyridz's Avatar
robbyridz
No Ideas anyone?
Old Apr 6, 2006 | 03:46 PM
Chrissy_bwoy's Avatar
Chrissy_bwoy
ICV is fitted under the inklet manifold and would be first point of call for an idle problem, other than that check the PBV valve which is on the front of the engine under the exhaust manifold, its on the right hand side as you look, bit of rubber with a tube going round the back. that oftens goes and is an easy fix
other than that get a diagnostics check done at fords as you could replace everything before you find the problem and sepnd far more than is needed to cure the prob
Old Apr 6, 2006 | 03:56 PM
SafeChav's Avatar
SafeChav
I'd say ISCV aswell as first port of call.
Old Apr 6, 2006 | 06:18 PM
robbyridz's Avatar
robbyridz
Cheers guys... I've got the day off work tommorow, so I'll get down to the breakers near me - they tend to be helpful and have plenty of zetec stuff
Old Apr 6, 2006 | 10:06 PM
SafeChav's Avatar
SafeChav
chances are mate its just dirty inside and they tend to stick, a clean usually does wonders for them.
Old Apr 6, 2006 | 10:16 PM
robbyridz's Avatar
robbyridz
now you say that, it does seem to be that before you put your foot down on the pedal the revs won't climb much - not like it used to be.
if i phone the breakers tommorow, am I just asking for and idle control valve?
i'm quite competant at working things out/ good with my hands - but not a ace mechanic - can fit things but not fault find should I be ok fitting it? I have all day
Old Apr 6, 2006 | 10:27 PM
SafeChav's Avatar
SafeChav
Mate they are very simple to do, couple of hours tops if you've never done it before. They are designed to be opened and cleaned, might save you a few pounds mate, but yes its called an idle speed control valve. Have a go at cleaning yours, Haynes manuals show how to do it
Old Apr 6, 2006 | 10:43 PM
robbyridz's Avatar
robbyridz
thanks for all the advice mate... i owe you a pint
Old Apr 6, 2006 | 10:50 PM
SafeChav's Avatar
SafeChav
Lol a few people have said that, if only uou could send a pint in a jiffy bag
You haven't got a lot to lose though, once off, theres 2 screws securing the motor to the aluminium housing with the valve in, they get oily and over time it goes sticky and thick.
Old Apr 7, 2006 | 06:33 PM
robbyridz's Avatar
robbyridz
sorted
when reassembling after clean, noticed one of the 2x wires for the ISCV connector was on by a thread put on some new wire and fitted a new connector - resolved
is idling quite high now though - how do you adjust the idle? in haynes manual it shows a screw somewhere on the throttlebody - can't see it though
Old Apr 7, 2006 | 11:49 PM
SafeChav's Avatar
SafeChav
Was it sticky inside aswell?
Right, as for the idle, i'm not too up on the finer aspects, BUT im sure the zetec management is a later developement of the EEC IV management, and i know 100% on that the idle speed is conrolled by the ECU and can't be adjusted with the throttle screw.
What is it idling at?
Old Apr 8, 2006 | 07:38 PM
deanh's Avatar
deanh
could anyone put up a pic of where the iscv is and what it looks like, mine sounds like it needs a clean too!
Old Apr 8, 2006 | 08:28 PM
robbyridz's Avatar
robbyridz
sits below the throttlebody, but is a bit of a pain to get to as is bolted on underneath the pipes on the inlet manifold takes a bit of knuckle bangin. (But then again, I'm not a mechanic so don't know if there is an easier way to get it off (bar removing the manifold, but don't fancy a new gasket)
Is silvery lookin
Mine will idle between 1000 and 1500, but sometimes sticks at 2000. If it goes down below 1000 it'll start burping and farting and if u dont apply some revvage it will cut out I lubricated the bar aswell.
I think it's time for a new one - what does everyone think?
Old Apr 8, 2006 | 08:39 PM
robbyridz's Avatar
robbyridz
infact, without looking again - anyone know what part no it is on the 1.8 Zetec (The ISCV)?
trying to source me a cheap one online
Old Apr 9, 2006 | 06:38 PM
deanh's Avatar
deanh
cheers mate im no mechanic either so im fooked if i know what to look for!!! lol
Old Apr 10, 2006 | 10:49 PM
robbyridz's Avatar
robbyridz
no problems dude what does... "choque" mean?
anywayz anyone know the part no I need? mindu I suppose not everyone is an encyclopedia of ford parts
I could always stop being lazy... and check on me iscv
Old May 2, 2006 | 02:29 PM
robbyridz's Avatar
robbyridz
it's in the garage again, still having the issue with idle (now it's started running rich as f**k aswell, getting about 200 miles to the tank )
they have had another look today but say the ISCV looks in perfect condition. They are getting another auto-electrician in tommorow to do another scan, now it's got worse - hopefully something will be uncovered.
any ideas, incase they don't find anything ?
Old May 2, 2006 | 02:31 PM
SafeChav's Avatar
SafeChav
Don't the RS1800's have lambda sensors?
Old May 2, 2006 | 02:36 PM
robbyridz's Avatar
robbyridz
it's not a rs1800, but yes - it has a lamda sensor, which was replaced for the MOT not long ago (problem was there before it's replacement aswell)
Old May 2, 2006 | 02:58 PM
SafeChav's Avatar
SafeChav
Hasn't anyone run a diagnostics checker over it yet
Old May 4, 2006 | 12:53 PM
robbyridz's Avatar
robbyridz
had 3 done, nothing uncovered (except afm, which I've since replaced)
Old May 4, 2006 | 01:30 PM
SafeChav's Avatar
SafeChav
God knows then
Old May 4, 2006 | 02:09 PM
robbyridz's Avatar
robbyridz
i'm just gonna make em replace me ICV, worst that will happen, is, it wil make no difference and i'm down a wad
if it dunt fix it, i'll class my existing ICV as ok - clean it up and sell it on ebay
Old May 4, 2006 | 02:11 PM
SafeChav's Avatar
SafeChav
I can get you a second hand ISCV if its any use to you? I doubt very much it is faulty so don't fork out for a new one
Old May 4, 2006 | 02:14 PM
robbyridz's Avatar
robbyridz
how much could you get me one for u reckoning?
Old May 4, 2006 | 09:21 PM
SafeChav's Avatar
SafeChav
Sent you a PM earlier which you havent read.
TPM961
Jan 15, 2018 10:50 AM
talon1
Sep 15, 2015 10:27 AM
BRAM
Sep 8, 2015 07:11 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
little bram
Sep 7, 2015 11:59 AM
