2wd cossie rear tyres going flat
Old May 4, 2006 | 09:50 PM
b14dave's Avatar
b14dave
Default 2wd cossie rear tyres going flat
heres 1 for ya my car can sit in garage for 2 weeks or more and not loose a bit of air when i go out and boot it 1 or the other will go flat,ok some mite say you got a puncture well i have 2 new fitted toyo proxies and have done bout 200mls till today the right rear went flat after bout 1hr of booting about pumped it up in the garage and its still up and lost no air,i thought possibly it was the rim but it is different sides everytime .
Old May 4, 2006 | 09:52 PM
rst_cabby's Avatar
rst_cabby
Are the to new one's both the one's going flat?
Old May 4, 2006 | 10:05 PM
b14dave's Avatar
b14dave
it used to do it before with the old tyres then i had to new ones fitted now its still doing it one day itl be left rear another day will be right rear pump up leave in garage couple of weeks and there be fine boot it about and one will go flat
Old May 4, 2006 | 10:08 PM
SafeChav's Avatar
SafeChav
I'll bet you when you're booting it the tyre is ballooning and pulling away from the rim.......
Old May 4, 2006 | 10:11 PM
rst_cabby's Avatar
rst_cabby
I know what it is ?
Wanna know do ya - do ya?
Old May 4, 2006 | 10:14 PM
b14dave's Avatar
b14dave
thats what ive been thinking or the tyre is spining on rim but their are cars with alot more horsepower bet they dont have this problem,must be the rims its gotta be its driving me mad
Old May 4, 2006 | 10:15 PM
b14dave's Avatar
b14dave
I know what it is ?
yea yea yea what is it?
Old May 4, 2006 | 10:19 PM
rst_cabby's Avatar
rst_cabby
If they are oldish rims then take them back to where you got the tyres fitted - have them take the tryes off & check the inside of the rim for corrosion (ALL ALLOYS GET IT) get them to clean them up with the buffer wheel & apply bead sealer when fitting back up - i take it they did change the valves?
The test for you to do is to get a bowl of very soapy water & apply to the rim of the tyre & rim of the wheel to see if it bubbles if it does you have a leak - the other thing to check is the valve with the same method - if no leak found take off wheels & check inside rim with the method again.
Other than that there is nothing else to try !!!
Hope this helps
Old May 4, 2006 | 10:21 PM
rst_cabby's Avatar
rst_cabby
Oh forgot to mention if they don't have bead sealer on the premises they are a cowboy outfit as all good fast fit centres do have it.
Old May 4, 2006 | 10:26 PM
b14dave's Avatar
b14dave
yea i got loads of beard sealer at work he he but being lazy as they stay up and i think there be alright ,might just treat myself to some new rims.
Old May 4, 2006 | 10:29 PM
SafeChav's Avatar
SafeChav
If it was the rims being corroded surely they would go flat whatever......not when he goes out for a blast.......as he said it sits in the garage for weeks on end, but as soon as he gives it some beans they lose pressure.
Old May 4, 2006 | 10:31 PM
rst_cabby's Avatar
rst_cabby
That's another way to solve it !
Old May 4, 2006 | 10:33 PM
rst_cabby's Avatar
rst_cabby
yes but if the leak is under weight it won't leak - that's why they only leak when it's on the move as the wall of the tyre is being moved from side to side.
I've seen it before many times when i was in the tyre trade ( 10 yrs to long )
Old May 4, 2006 | 10:38 PM
SafeChav's Avatar
SafeChav
Ah right then thats fair enough
b14dave's Avatar
b14dave
true if they were corroded and the rim of the tyre sat against the corroded part then they would leak sitting there,but when they inspected the rims to find the leak the rims wasnt corroded as thats what they thought hmmm think im just gonna start from scratch new rims,new valves,new tyres s it must be only me who has this problem with keeping it up for long time it aint running serious power so can only be rims maybe there cracked and when they get warm or put under power they open up scary
Oct 9, 2015 07:38 PM
FlashRS
13
Aug 31, 2015 06:02 PM
rog
Aug 30, 2015 05:32 PM
IAN RS2k
Aug 18, 2015 07:51 PM
RsS2daz
Aug 14, 2015 05:26 AM
