COMETIC Multi-layer gaskets
Old Feb 4, 2006 | 07:55 PM
JjCoDeX75's Avatar
JjCoDeX75
Default COMETIC Multi-layer gaskets
Hi all
Anyone got any experience with the above? I have just blown my Gp A Head Gasket after all of 9k miles!!
Running quite high boost - approx 26psi, and as such need to replace with an uprated item. Cometic multi layer much cheaper than WRC Multi-layer. Is this good enough for the pressure I am running? Or should I cough up the massive amount of extra dosh?!¬?!
Help!?
Ta
JJ
Old Feb 5, 2006 | 08:25 AM
rssapphowner's Avatar
rssapphowner
yep they are the tits mate you can reuse them too never had any leaks yet go for it mate by the way i peak at 2bar and hold 1.5bar boost with standar cooler
Old Feb 5, 2006 | 08:44 AM
Dave Henshall's Avatar
Dave Henshall
u cant reuse them as the viton coverings come away when you split them down - -a word of warning tyhough (learn from others mistakes; ie me ) unless both the head and block are 100% flat and smooth and clean - it wont make a good seal and your 150 quid for the gasket and 25 for the bolts will have just been wasted
here is what happens when u take it apart again.. there should be no bare metal exposed
Old Feb 5, 2006 | 11:02 AM
JjCoDeX75's Avatar
JjCoDeX75
Cool
the GP A gasket had only a soft failure. All surfaces will be checked for flatness before re-assembly.
Most important thing to find out is that the cometic was up to the job.
Not to worried about re-using - hopefully wont need to dissassemble for a while! (Fingers crossed)
Old Feb 5, 2006 | 04:06 PM
rssapphowner
it dont matter about the coating mate mines still good on its second use
Old Feb 5, 2006 | 09:41 PM
simonc's Avatar
simonc
My cometic has been good so far but i had the block decked & head skimed before fitting.
Simon.
Old Feb 7, 2006 | 05:46 PM
JjCoDeX75's Avatar
JjCoDeX75
Hmm
I had the engine totally rebuilt less than 10k ago, and the head gasket failure I have had is a soft failure (leak) rather than hard failure (overheat).
I am hoping not to have to skim head again, though will measure and decide on the day!
Thanks one and all for the advice given
JJ
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
Brickhouse
Sep 23, 2015 06:28 AM
pie-face
Sep 15, 2015 10:43 AM
