What clay are you using?
Old Jul 1, 2013 | 07:10 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Default What clay are you using?
As above, nearly picked up a Megs kit on the way home but thought I better get some opinions first.
Who's clay do you use? And what lube are you using?
Is it easy to work? I've read that some can be a bit of a pain to work with.
My car needs a good detail but I refuse to polish it until it's had a good clay!
Ben.
Old Jul 2, 2013 | 09:37 AM
uruk hai's Avatar
uruk hai
I use Bilt Hamber medium Autoclay and you only need tap water as lube making it very cost effective.
Old Jul 2, 2013 | 09:56 AM
Heitmann's Avatar
Heitmann
I haven't noticed big difference on the clays ive tried
But using enough lube is the key I think - just use tap water with a little soap added
Old Jul 2, 2013 | 12:30 PM
J1mbo's Avatar
J1mbo
B1mbo
I use megs with quick detail an it was very good and easy to work with so would reccomend.nnot to mention you have loads of quick detail left over which is good stuff anyway
Old Jul 2, 2013 | 02:04 PM
RichieST's Avatar
RichieST
Apparently - not sure how true it is, clay is just clay. There is only one hole in the ground in the world that detailing clay comes from, so no matter what brand you choose, it is all identical apart from some different dye!
Old Jul 2, 2013 | 03:52 PM
Longdog3004's Avatar
Longdog3004
What dose clay do to your paint work?
Old Jul 2, 2013 | 05:18 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Cheers guys.
Claying removes contaminants on your paintwork that a regular wash or even snow foam won't remove.
Should always clay before you polish so you don't rub the contaminants into the paint.
Old Jul 2, 2013 | 05:20 PM
Longdog3004
Ah ok cheers
So how do you use this?
Rub on and wipe off?
Old Jul 2, 2013 | 07:43 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
It's pretty much a bar of clay mate, not a lot else too it! Just rub it around your paint with the help of a lubricant.
Old Jul 2, 2013 | 09:23 PM
Retro Al's Avatar
Retro Al
RWD IS KING
Clay bars are not made from the clay you get out of the ground
Megs autogylm or bilt and hamber and all good and can be used with just water,there are some on ebay that are cheap and they are crap, they break up a lot quicker and don't fold very well imo
Old Jul 2, 2013 | 09:33 PM
RichieST's Avatar
RichieST
What is it made of then?
Old Jul 2, 2013 | 09:38 PM
Retro Al's Avatar
Retro Al
RWD IS KING
They are Synthetic / man made if you like
Old Jul 3, 2013 | 09:19 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i've been using the meguires one but has come to an end now.
i'm trying a g3 one now, see how that goes, seems a bit stiffer so may pull a bit better.
as for lube, i got megs quick detailer, but waste don claying really. just a bit of chemical boys soap/gel and water in a spray bottle works well.
i got the g3 clay bar in a kit with an applicator, don't bother, it's bloody useless and will scratch the paint, happily that worked out as a freebie.
Old Jul 4, 2013 | 09:53 AM
v man's Avatar
v man
Zee Germans are coming
Ah ok cheers
Just watch some vids on YouTube
Old Jul 9, 2013 | 02:11 PM
I use the Auto glym clay bar.
Old Aug 5, 2013 | 08:33 PM
jaiscossie's Avatar
jaiscossie
Dig a piece of clay out of the ground,pick out any large stones etc then wipe over your paintwork for a lovely swirl free finish
spookie
20
Nov 17, 2008 03:05 PM
BM08
Concours d'élégance.
Oct 20, 2008 04:03 PM
CraigoScott
May 12, 2007 04:15 AM
Dan
Jun 7, 2006 06:13 PM
