Autoglym sealer
Old May 19, 2008 | 10:25 PM
roro22's Avatar
roro22
Smile Autoglym sealer
I found some I've had but not really used much.
How does this rate? I've not really used sealer before so can't compare it
Thanks
Old May 20, 2008 | 06:49 AM
iansoutham's Avatar
iansoutham
OCD Victim
If you are taking about the Extra Gloss Protection then I recommend it. There are others out on the market, but it does the job.
I find that making sure the car is fully cleaned first (including removing of any watermarks) then apply it and leave it for an hour gives a nice finish. Buff it off and away you go. Some people say that is all you need, but I always prefer to put a coat or 2 of a decent wax on afterwards to aid longevity.
Old May 21, 2008 | 10:35 AM
roro22's Avatar
roro22
Yeah thats the stuff.
Need to try it out properly this week
thanks
Old May 21, 2008 | 06:00 PM
sean2k's Avatar
sean2k
is that the paint protection 1 or is that the polish 1? cheers sean2k
Old May 21, 2008 | 10:36 PM
roro22's Avatar
roro22
the one with the gold autoglym label the gloss protection
Old May 22, 2008 | 09:16 AM
Matt Evans's Avatar
Matt Evans
Black Country RSOC
100% spot on mate
Its best used prior to the finishing coat of wax.
Old May 22, 2008 | 12:39 PM
roro22's Avatar
roro22
I think I used it back to front, I used megs stage 3 wax then the sealant. Want to get different wax soon as I'm not 100% happy with it but it will do till the bottle runs out lol
Old May 22, 2008 | 04:28 PM
Gav Diamond's Avatar
Gav Diamond
Yes mate, you should seal then wax ontop but to be fair the megs stage 3 is not very good anyway.
Old May 23, 2008 | 11:50 PM
roro22's Avatar
roro22
Ill try that tomorrow, shiny get additive
Old May 24, 2008 | 09:03 PM
sean2k's Avatar
sean2k
how do u use it then wash the car and go from there cheers sean2k
Old May 24, 2008 | 10:56 PM
iansoutham's Avatar
iansoutham
OCD Victim
Clean the car thoroughly, including machine mopping or claying if necessary. Dry the car and then use a Quik Detailer and wipe over the surface again, removing any dust, watermarks, etc... from the paintwork. Sealers do EXACTLY what they are marketed as. They seal paint and anything on it, including watermarks.
You can then either use a filler polish (something like AG SRP) to mask any fine scratches or, if the paintwork is to a suitable standard, go straight in with the AG EGP. If using a polish first, remember to redo a QD once-over once cured to remove any polish residue or dust.
Apply the EGP gently to an applicator pad and wipe over the surface, ensuring even coverage. Trust me, a little goes a long way with sealers.
Leave it for @ least 30 minutes to an hour to cure properly, and do not apply to hot paint or in direct sunlight. Remove with a microfibre cloth and then apply a decent wax after another application of QD.
3i Jim
Nov 20, 2015 05:12 AM
3drRich
Sep 13, 2015 07:32 PM
cameron2
12
Sep 4, 2015 01:34 PM
Gadget
Ford Escort RS Cosworth
Aug 14, 2015 07:19 AM
Gadget
Aug 13, 2015 08:19 PM
