pc problem....
Old Nov 2, 2013 | 03:46 PM
fuzzy's Avatar
fuzzy
14000+ post superhero
Default pc problem....
....my pc seems to be running a bit slow and notchy over the last couple of days when scrolling through pages. the pages load up as quick as usual though. ive done a full scan with my security which showed no problems and ive also tried a system restore but its not helped. system resore worked the last time i had this problem.
any hints that a computer novice could try or does it sound like a trip to the pc shop is required ?
please reply in plain english though and not computer geek talk so i can understand you....
Old Nov 2, 2013 | 04:31 PM
TommysKeeper's Avatar
TommysKeeper
You don't say what security you are running but try downloading MALWAREBYTES and running a full scan of your PC with that. You can safely download from www.download.com
Don't forget to report back and let us all know how you get on.
Cheers, John
Old Nov 2, 2013 | 04:39 PM
fuzzy's Avatar
fuzzy
its mcafee security.
ive always been suspiscious of security products as i always seem to start having problems as the years subscription is nearing its end. i reckon they deliberately infect you with their own viruses so youll upgrade their product.
can the malwarebytes be downloaded on a protected pc or will it need mcafee uninstalled before itll work?
Old Nov 2, 2013 | 05:21 PM
Chopshop85's Avatar
Chopshop85
When its starting to chug. Hit ctrl+Alt+delete. Click task manager. and look at performance and processes tabs.
The performance tab will tell you what your load you cpu is at and how much ram is being used.
The processes tab will show you whats running and whats hogging all the juice.
Always a good place to start.
Old Nov 2, 2013 | 05:25 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Do you have a lot of programs running at once? Or even stuff running in the background? My laptop was slow, turned out that it was running 13 programs on start up, all unnecessary! Stopped them all and it was fine.
Old Nov 2, 2013 | 06:14 PM
ste1806's Avatar
ste1806
ccleaner is very good program for uncluttering your pc. http://www.piriform.com/ccleaner
Old Nov 2, 2013 | 07:39 PM
TommysKeeper
Yes you can download, install and run Malwarebytes with McAfee running.
Cheers, john
Old Nov 3, 2013 | 12:39 PM
fuzzy's Avatar
fuzzy
just did that but it means nothing to me.
73 processes
0-10% cpu usage (fluctuating)
29% physical memory
1.15 gb memory
theres a big list of stuff in the processes but i dont actually know what they are or what they mean?
Old Nov 3, 2013 | 12:42 PM
fuzzy's Avatar
fuzzy
Cheers, John
my pc security is blocking the download saying it contains potentially dangerous material?
Old Nov 3, 2013 | 12:56 PM
BigChuck's Avatar
BigChuck
If it was me, I'd do a malwarebytes scan, download and run ccleaner and download and run glary utilities. The three of them will clean the crap out of the PC and speed everything up.
Old Nov 3, 2013 | 12:57 PM
Chopshop85's Avatar
Chopshop85
73 processes
29% physical memory
1.15 gb memory
That is what percentage of your computers components are being used.
So what is happening with your computer it is not throttling either the RAM or CPU.
Its when those figures get nearer 80% you'll usually start to notice slow down.
So maybe it a browser issue, or display driver.
What web browser do you use?
Old Nov 3, 2013 | 01:04 PM
BM08's Avatar
BM08
Isn't 73 processes abit much? Lol
Think we have about 15-20 on our laptop as an example
Old Nov 3, 2013 | 01:08 PM
Chopshop85's Avatar
Chopshop85
No. Its more what load the CPU is at rather than the processes.
Example. I have 6 tabs open with goggle chrom at the moment so thats 11 processes just from chrome.
I only have windows, nvidia experience, D3D overide on my taskbar and thats 48 processes.
Old Nov 3, 2013 | 01:38 PM
fuzzy's Avatar
fuzzy
its google i use as my web browser . whats the display driver?
my security is blocking that malware download .
Old Nov 3, 2013 | 01:46 PM
Eagle's Avatar
Eagle
Super Moderator
how old is it and what version of windows is it ?
Old Nov 3, 2013 | 01:47 PM
Chopshop85's Avatar
Chopshop85
Try a different web browser and see if the problem persists.
Old Nov 3, 2013 | 01:51 PM
martysmartie's Avatar
martysmartie
Each process consumes memory though, so that can affect performance (although not a problem in this case)
These days though most applications have there own update service etc, and iTunes has several processes alone, as the newer Windows OS's have more services than ever.
As said though, if you use Chrome try Internet explorer and see if you have the same problem, more than likely it's a problem with the browser, caused by a bad add-on, for example. You can run IE without any of these load for troubleshooting purposes, not sure if Chrome has a similar feature?
The display driver if for your graphics card, there may be a newer version, although I doubt this is causing this issue.
Martin
Old Nov 3, 2013 | 04:07 PM
fuzzy's Avatar
fuzzy
its an HP ,ts about 2 years old and its on windows 7.
ive undone the last system resore and removed a spotify and a event manager process from the task manager and that helped but when i shut down and started up the pc again the 2 processes had returned. how do i remove them completely so they dont return as the trouble seemed to coinside with these two programs appearing on my pc? the spotify window keeps popping up all the time but theres no sign of it when i click on all programs in the control panel?
Old Nov 3, 2013 | 04:13 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Have you tried kicking it?
Old Nov 3, 2013 | 04:25 PM
Fullflush's Avatar
Fullflush
use ccleaner to control what runs at startup. Also do a full clean with it.
Malbytes is fine, ignore the block message.
Remove mcafee (just uninstalling it will make you computer loads faster) and use avast. free and less draining on system resources. Use comodo for a firewall, which is also free.
Old Nov 3, 2013 | 04:27 PM
Chopshop85's Avatar
Chopshop85
Click on start. In the "search programs and files" bar, type "msconfig". You'll see it appear at the top of the start bar. Launch it.
On the system configuration box there will be a "startup". You can see what programs are starting at launch, then untick the ones you don't want on start up.
Old Nov 3, 2013 | 04:37 PM
fuzzy's Avatar
fuzzy
im a man. thats the very first thing i tried. and the second
Old Nov 3, 2013 | 04:39 PM
fuzzy's Avatar
fuzzy
thanks for the info guys. i take back half the stuff ive said about you. your not that bad really.
Old Nov 3, 2013 | 04:43 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Old Nov 3, 2013 | 06:32 PM
Eagle's Avatar
Eagle
Super Moderator
agree .. if you open ccleaner and goto tools then startup you can disable anything from running when you boot up. its amazing on how a 2 year old pc the amount of stuff that runs when you boot up..
Old Nov 3, 2013 | 06:35 PM
MrC's Avatar
MrC
Have you tried rebooting it??
Old Nov 3, 2013 | 06:47 PM
RichieST's Avatar
RichieST
ccleaner is a great tool, download it and run it to remove a load of un-needed crap off of your machine.
Then delete stuff you don't use any more. Click the start menu then in the search box type in uninstall. Click the 'uninstall a program'. Run through the list and delete anything you have installed but don't use.
Restart your computer to complete uninstallation of some programs that may need it, then in the same search box, type in defragment. Open up the disk defragmenter and defragment your C drive. Depending on how bad it is it could take a couple of hours, so just leave it to run and don't be tempted to cancel it half way through.
After that, you should find your machine running a bit better!
Old Nov 3, 2013 | 07:07 PM
fuzzy's Avatar
fuzzy
yes, ive already said i kicked it twice.
i diod a scan on the malbyteware, 405 errors it found, unfortunately the free download only removes 15....
Old Nov 3, 2013 | 07:09 PM
RichieST's Avatar
RichieST
a, download some proper antivirus software.
b, stop downloading goat porn.
Old Nov 3, 2013 | 07:10 PM
MrC's Avatar
MrC
Err malware bytes doesn't scan for errors??? It scans for spyware, and the free version you can remove all infections, sounds like you downloaded more spyware, another dodgy program lol
Old Nov 3, 2013 | 07:21 PM
RichieST's Avatar
RichieST
Sounds to me like a format and a fresh install is required lol
Old Nov 3, 2013 | 07:23 PM
MrC's Avatar
MrC
Hahaha it's just getting better and better lmfao trying to get rid of spyware, and downloading more with fake security spyware program's
Priceless
Old Nov 3, 2013 | 07:53 PM
fuzzy's Avatar
fuzzy
ive just un installed everything i could find registered to todays date. is the link near the top duff because thats were i downloaded it from?
i cant really say im to bothered about spyware. my personal details wouldnt get you credit anywhere and if someone wants to hack my bank to clear some of my debts i wont stop them
the scrollings a lot smoother now and the goat porn videos arent as notchy now so ill leave it until my security runs out next month.
Old Nov 3, 2013 | 07:59 PM
MrC's Avatar
MrC
Yeah the sponsored links at the top are dodgy mate, go to filehippo.com and download ccleaner and malwarebytes and run them from there.
Then report back, have a look on startup aswell to if there's stuff running that doesn't need to be, open your start menu and type in msconfig and untick what you don't need running on startup,
Old Nov 6, 2013 | 05:40 PM
fuzzy's Avatar
fuzzy
after getting a coincidental email today from mcafee trying to sell me software to fix slow running pc's its just reinforced my belief that the security deliberately infects you nearing the end of your contract time so you pay more to upgrade so i un installed everything to do with mcafee and downloaded microsoft security essentials, scanned and cleaned it up and everythings running good again...
bring on the goat porn vidoes.....
Old Nov 6, 2013 | 06:02 PM
Chopshop85's Avatar
Chopshop85
The best form of anti virus is common sense.
Avoid using torrents.
No illegal websites/software.
If you don't recognise the email address, don't open the attachment.
etc....
Dr. Ickxs
Aug 15, 2015 11:34 AM
grass racer
Apr 8, 2014 09:05 PM
blackbeautyzetec
Jan 6, 2012 05:15 PM
Rollinz
Sep 22, 2011 05:26 PM
RS Juto
Mar 13, 2011 07:37 PM
