power steering issues please help
ok here goes.. replaced all power steering pipes on the rack as they wer all leaking. now my steering wont respond it violently jiggers from left to right will only turn from left to right sometimes if i hold it but does it by itself it will not allow me to turn from lock to lock by myself tried bleeding the system to no avail when i empty the fluid i can turn from lock to lock but as soon as i put the fluid back in it does the same thing again. its new fluid everytime. any hints or tips would be greatl appreciated thanks.
there is no leaks but im thinking possibly air being drawn in at the rack where the input and return pipe enter and exit? as they don't seem to be tight with the 1 10mm bolt that holds both of them in with the o rings?
Sure I've heard before, that you have to bleed it with the wheels on the ground, whereas some people do it with the wheels in the air? I'm no expert, don't think I've ever had the need to bleed mine!?
tried doing it with the wheels on the ground it was worse trying it that way i haven't had a chance to look at it propely yet because of this damn weather! maybe ill have a bit of luck on sunday
JK12
33
26-04-2021 12:09 PM
DixieTheKid
11
06-06-2020 11:20 AM
