2.0/2.1 CVH
Old Jan 1, 2006 | 08:00 PM
SafeChav's Avatar
SafeChav
Default 2.0/2.1 CVH
Is it possible to make a CVH 2.0/2.1 litre?
I see a Zetec block is the same physical size and dimensions, so therefore is it not possible to bore a CVH block out to 86mm or whatever it is to achieve 2.0 capacity?
(for a turbo'd engine by the way)
Old Jan 1, 2006 | 09:15 PM
Karl's Avatar
Karl
Norris Motorsport
No
Old Jan 1, 2006 | 09:35 PM
SafeChav's Avatar
SafeChav
Whats the reason for this just out of interest?
Old Jan 2, 2006 | 06:27 AM
JesseT's Avatar
JesseT
Boring a 1.6 is out of the question. Would be very easy though to build a 2.0CVH from a SPI engine.
Old Jan 2, 2006 | 12:37 PM
SafeChav's Avatar
SafeChav
You say boring out a CVH is out of the question, does that mean its not possible, or not practical to?
Whats an SPI engine?
Old Jan 2, 2006 | 03:02 PM
DazC's Avatar
DazC
Not possible. The walls of the bore would not be there anymore.
Old Jan 2, 2006 | 03:05 PM
SafeChav's Avatar
SafeChav
Ok
exscuse my ignorance on this, how do you achieve 2.0 on a zetec block then, from a top cross sectional area view they are exactly the same size are they not? Hence why you can fit a CVH head on? SO surely you must be able to bore it out to 86mm as per a Zetec block? If that makes sense?
Or does boring to 86mm on a CVH not achieve 2.0l, meaning the Zetec block must be taller, as in longer stroke bores?
Old Jan 2, 2006 | 05:14 PM
DazC's Avatar
DazC
The Zetec has a longer stroke....
Old Jan 2, 2006 | 05:42 PM
JesseT's Avatar
JesseT
And the 2.0 zetec has siamesed bores. That is, the walls are so thick that there's no water between the bores. Quite different to a 1.8 Zetec or 1.6CVH block. So, you can't bore a 1.8 Zetec to 2.0 either.
Old Jan 2, 2006 | 06:07 PM
SafeChav's Avatar
SafeChav
Bollucks
Whats the furthest you can take a CVH to then?
Presumeably the 1.9 American blocks are taller? And can they reach 2.0?
Old Jan 2, 2006 | 08:18 PM
Rick's Avatar
Rick
Originally Posted by safechav
Bollucks
U are missing the point. Why would u want to increase the capacity?
Old Jan 2, 2006 | 10:01 PM
jayRS's Avatar
jayRS
am i right in thinking the max you can get out of a cvh is 1800, but in doing so your boarded lining the bore wall thickness for strenght, as in give it to much $hit and ya crack the bore
Old Jan 2, 2006 | 11:57 PM
SafeChav's Avatar
SafeChav
Bollucks
Am i being incredibly dumb or does higher capacity not mean more power?
I thought this was the whole reason for ZVH's etc, except i want to keep it as close to the original engine as possible.
Old Jan 3, 2006 | 08:11 AM
JesseT's Avatar
JesseT
Out of what CVH? Remember that also 1.8, 1.9 and 2.0 variants have been used by Ford from new.
Old Jan 3, 2006 | 05:46 PM
jayRS's Avatar
jayRS
yeah i know but the blocks are different.
but there was a xr2 40, 40 made with 1.8 engine, limited edition jobbey.
from what i remember the blocks were 1600 blockes bored to 1.8
mk3ste
Oct 17, 2021 10:09 AM
sridgett
13
Sep 27, 2015 06:03 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 03:19 PM
Russp
Escort Range
Sep 18, 2015 07:39 PM
