oil pressure /water temperature
Old Jan 2, 2006 | 02:52 PM
cosbag's Avatar
cosbag
Default oil pressure /water temperature
i have just fitted gauges to my car and wondered if anyone knows what the oil pressure and water temperature should be on a 1990 2wd cossie , i would be very grateful for any info many thanks cosbag
Old Jan 3, 2006 | 10:18 PM
grease monkey's Avatar
grease monkey
the coolant temp should be around 90 degrees give or take .
the oil pressure should about 60 psi when fully warm at 2500 to3000 revs and should be no lower than 20 psi at idle.
these are only rough estimates but hope this gives ya n idea
SMILER258
Sep 28, 2015 09:04 AM
