rst starting problem when hot
Old Dec 12, 2005 | 01:58 PM
ADSRST's Avatar
ADSRST
Default rst starting problem when hot
please help coz this gets embarasing i can drive the car fine but if i stop the car and turn off the engine then come back to start it a couple of minutes later it wont turn over properly i have to leave it for about 20 mins or so before it will start again.
id like a bit of info because this used to happen on one of my old 3is is it something with the cvh's or their starter motors or something else
cheers adam
Old Dec 12, 2005 | 02:44 PM
antony215's Avatar
antony215
Escort Rs Turbo
starter go to ford and get the heatshield then you wont have anymore problems
Old Dec 12, 2005 | 05:33 PM
HORNETS7's Avatar
HORNETS7
as above that is if ford still do them someone told me they don't but i bought one about 2 years ago dunno about now?
Old Dec 12, 2005 | 05:48 PM
RSandy's Avatar
RSandy
i asked ford a few months ago n they sed it was a discontinued part, n they like rocking horse shit 2nd hand!!!
if sum1 provides and accurate finis code, im sure ford mite b able to make sure there arent any left in stock, most ford places just tel u they dnt do it anymore to save themselves the hassle of findin it on teh computer
Old Dec 12, 2005 | 06:49 PM
Micky's Avatar
Micky
Why not fit heat wrap on the starter motor and down pipe??Easy,job done!! Regards Micky
Old Dec 12, 2005 | 06:53 PM
Damo V's Avatar
Damo V
current drain/starter, just fit another relay down near the starter, with a new feed to it direct from battery, sorted, had exactly the same on my oldS2, did that job done/...
Damo V's Avatar
Damo V
I should add, you will find it you short the wires across on the starter, it will crank even if it doesnt on the key
Old Dec 12, 2005 | 06:54 PM
Mk1-stu's Avatar
Mk1-stu
Patronus
series one or two rs ? or don't it matter...?
Old Dec 12, 2005 | 06:56 PM
Damo V's Avatar
Damo V
dont matter bothe suffer
Old Dec 12, 2005 | 06:57 PM
Mk1-stu's Avatar
Mk1-stu
Patronus
lol... i know someone who make's custom parts... he might already be making the heat shield... i will ask him tomorrow
Old Dec 13, 2005 | 07:58 AM
ADSRST's Avatar
ADSRST
thanks ror all you advice ill be looking for one of the heat sheilds then if i cant find one then ill wrap it
thanks again
cheers adam
Billy_RS
16
Oct 11, 2025 09:41 PM
A.t.p
Aug 15, 2015 11:37 AM
Sjieter
Aug 5, 2015 09:47 PM
dlwarrior
Aug 5, 2015 10:19 AM
fish6634
Ford KA
Aug 2, 2015 01:02 PM
