turbo technics part numbers??
i have recently acquired a bargain hybrid turbo technics t3 unit for my s2, but im unsure of the exact spec. is there anywhere on the unit itself with a part number that specifies the exact spec?? i kno its hybrid, but wud b nice to kno exactly wot stage it is.
even if it was standard spec i wudnt care, as a brand new turbo with collins actuator and inlet manifold for 100 quid isnt bad in my eyes!! lol
The Turbo Technics turbo i have on my car has a plate on the compressor housing, there is a serial number and some other info on there.
Maybe if you give Turbo Technics a call with this information they may hold records of the turbos they have built.
cheers mate, sum1 once told me about a part number cast into the unit itself sumwhere, but i cudnt see it when i looked earlier. maybe i missed it, i dnt kno, but i wil check that small plate, get a magnifying glass out, and try and read wotever that says
No problem, as you say the compressor/turbine housing sizes will be cast into the housings but this wont tell you other infoormation eg type of thrust bearing
what r the main difference between the stages on a hybrid?? eg, the changes frm stage 1 to stage 2?? will i be able to tell anything frm looking at the unit, or wil it b all internal changes, that cnt b seen thru the blades?? mite sound stupid, but iv neva had to mess with a turbo before, n im keen to kno if my bargain turbo turns out to b even more of a bargain if its higher spec'd
paceo
03-02-2016 10:31 AM
Matt Baxter
16-09-2015 08:30 PM
muz
16-08-2015 12:57 PM
