cossie timing
Old Jul 10, 2004 | 06:31 PM
rossatom2's Avatar
rossatom2
Default cossie timing
after changing the bottom end twice and going through 3 different heads on my 2wd cossie i have come to the conclusion that the tapping in my engine must be the timing out.
i put bottom pulley to lug next to groove
top pulleys to each other
aux pully to the half moon .
would the pistons tap the valves if it was onlt very slightly out??
it turns over easy by hand but taps when running.
thanx
Old Jul 11, 2004 | 06:31 AM
richm's Avatar
richm
sounds like you have everything set right -
AFAIK the valves should never touch unless the belt is at least a whole tooth out... and that would be very obvious when you line all the marks up..
apologies if the pic is a bit big, but left to keep clarity
Old Sep 12, 2004 | 10:49 PM
blaazer2's Avatar
blaazer2
TAKE No1 SPARK PLUG OUT GET IT TO TDC 1 AND 4 GET A DIAL GAUGE IN AND CHECK IT WITH YOUR FRONT PULLEY TIMING MARKS
Old Sep 13, 2004 | 08:05 AM
foreigneRS's Avatar
foreigneRS
Testing the future
they do tap if the timing is out by one tooth, but you should be able to see it.
Billy_RS
16
Oct 11, 2025 09:41 PM
kosienutter
31
Aug 22, 2015 09:55 AM
y4n
Aug 17, 2015 12:12 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
