back fire when switch of engine still need help
Old Sep 13, 2005 | 04:03 PM
ASHCOSSIE's Avatar
ASHCOSSIE
Default back fire when switch of engine still need help
hi when i turn of my rs s2 get out of car ya get a big bang from exhaust any thoughts sounds like a back fire why is it doing this makes people jump whitch is quite funny but want it to stop help
Old Sep 13, 2005 | 04:20 PM
Dave Henshall's Avatar
Dave Henshall
its not got a daft flamer on or similar has it?
Old Sep 13, 2005 | 04:50 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
sound poss like timing m8
Old Sep 13, 2005 | 07:27 PM
akito-man's Avatar
akito-man
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
Old Sep 13, 2005 | 10:26 PM
GrimmeRS2K's Avatar
GrimmeRS2K
cam timing proberly a tooth out
Old Sep 14, 2005 | 12:16 AM
jazraymcbeath's Avatar
jazraymcbeath
you probably have a leaky injector or warm up injector and the fuel will self ignite with the heat off the pistons
Old Sep 14, 2005 | 07:51 AM
carlosl's Avatar
carlosl
the car has no flamer kit but ill check the timing i would of thought if it was a tooth out it would feel all boged down but it dosent i will still check thanks
Old Sep 14, 2005 | 10:34 AM
mart.rs's Avatar
mart.rs
Old Sep 14, 2005 | 07:23 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
still think timing get it checked my s2 done exact same got it set up and gone
Old Sep 30, 2005 | 08:51 PM
steve90spec's Avatar
steve90spec
my car has same prob ,I put it down to unburnt fuel igniting inside the hot exhaust after the engine was switched of
Old Oct 1, 2005 | 02:13 PM
escortrsmatt's Avatar
escortrsmatt
mine used to do this if i switched off the engine without letting it idle for a coupla minutes
Old Oct 1, 2005 | 05:49 PM
turbo.jon's Avatar
turbo.jon
i have same problem but i think it is timing as i did it all when put it back together just need it set up now an hopefully will be sorted....
Old Oct 3, 2005 | 10:31 AM
ASHCOSSIE's Avatar
ASHCOSSIE
i have now got around to checking static timing and its spot on i am running a 1.9 is it worth finding the true tdc with a dti gage as i never new about that untill i had built the engine nowmatter if i advance or retard the timing it still goes bang so i dont now what to do any ideas
Old Oct 6, 2005 | 02:55 PM
ASHCOSSIE's Avatar
ASHCOSSIE
help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!still no wiser
Old Oct 6, 2005 | 05:16 PM
GrimmeRS2K's Avatar
GrimmeRS2K
my car does it, it didnt do it before i changed my cambelt, so mine must be 1 tooth out, cant be arsed to change it, like annoying the neighbors with a gunshot sound at night
Old Oct 7, 2005 | 04:08 PM
JamboRS's Avatar
JamboRS
focus rs 1672
mines done it and it had been set up fine
dont know why it does it but its quite common on rs turbo's
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
ekjim
Aug 17, 2015 08:57 PM
Bailes1992
Aug 16, 2015 07:14 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
