Ferrodo DS2500 brake pads - your experience ?
Old Sep 9, 2005 | 04:05 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Default Ferrodo DS2500 brake pads - your experience ?
Quick question for those who run / have run these pads before.
We have them on our 2wd cossie with drilled and slotted discs up front, std discs at the back.
Returning from TRAX, we drove for a while on the A34 without touching the brakes, got up a slip road to a roundabout, rolling up the hill and slowing naturally (without brakes), started to brake just before the roundabout and f*****************k, hardly any breaking at all, had to stomp really hard on the pedal to stop.
Later on, the brakes were fine on country lanes.
So, are the DS2500 inefficient if they haven't been warmed up a little before hand ? Not noticed that problem before, and I guess they were stone cold when we got to that roundabout.
Old Sep 10, 2005 | 12:08 PM
frog's Avatar
frog
Old Sep 10, 2005 | 03:13 PM
Dave Henshall's Avatar
Dave Henshall
i have teh ds2000 all rounnd and once they are warm they are mega, yep the first time from cold they are not 100% but i wouldnt expect to the extent u descibe maybe something else....? i know the 2500's are hotter pad than the 2000, so may be...?
Old Sep 10, 2005 | 06:48 PM
frog's Avatar
frog
Cheers Dave, I will keep an eye on it, but they otherwise work fine, could have got cold after a long drive with no brake application...
Old Sep 14, 2005 | 05:14 PM
Eagle's Avatar
Eagle
Super Moderator
i have not had any probs with mine... work well from cold must just be your right foot is a bit light and floppy
Old Sep 14, 2005 | 06:53 PM
frog's Avatar
frog
As long as the rest is heavy and stiff, I don't mind
Will just have to keep an eye on it when we next go for a long drive.
Old Sep 14, 2005 | 06:58 PM
Azrael's Avatar
Azrael
My DS2500 are great even in cold temperatures. Maybe when cold breaking feel is a little bit dull but apart from that I cannot complain in any way. And I abused them really hard as I left-foot-brake far to much sometimes.
Old Sep 19, 2005 | 12:56 PM
Stu @ M Developments's Avatar
PassionFords Creator
I used 2500s in all my cossies and they are fine cold.
More likely is your calipers are sticking and you actually got the too HOT and experienced FADE. Check your wheels after driving around with virtually no braking, see if they feel HOT.
Old Sep 19, 2005 | 02:08 PM
frog's Avatar
frog
Thanks Stu, that sounds like a likely story on a 19 year old car
Nov 1, 2015 06:53 PM
Oranoco
12
Oct 2, 2015 02:18 PM
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
