what boost with 803s and chip
Old Feb 5, 2015 | 11:03 PM
Richard89cosworth's Avatar
Richard89cosworth
Default what boost with 803s and chip
ok so I bought my sierra cosworth from a chap that knew nothing about it,
I was given a folder and there are recipts for the following
bosch 803s and chip -32 actuator.
its dynod at 243bhp and running 9psi I thought with 803s and chip it should be able to run 15psi and be able to make 330+
tempted to get a boost controller and give it the 15psi and see how she goes.
thought plz ?
it has t 34+big intercooler so no worries about making the boost or cooling.
Old Feb 6, 2015 | 01:18 PM
Caddyshack's Avatar
Caddyshack
I would take it to someone and get it mapped properly instead of winding up the boost. You need the fuelling correct along with timing. I would get it live mapped and end up with a more responsive and faster car.
Old Feb 6, 2015 | 06:39 PM
costina's Avatar
costina
Live long and prosper!!
Great advice greens can fuel 350 bhp easy boost holding 23psi.
Get it set up and checked.
Old Feb 6, 2015 | 09:11 PM
Richard89cosworth
I dident think you could remap a l6 ?
Old Feb 7, 2015 | 08:21 AM
costina's Avatar
costina
Take it to a specialist.
Old Feb 7, 2015 | 08:26 AM
Staffi's Avatar
Staffi
You can bud, weber mappers are Tony @ TurboSystems , MSD, NMS, all very good.
Where in the country are you??
Old Feb 7, 2015 | 09:26 AM
Stu @ M Developments's Avatar
PassionFords Creator
You can live map the L6 no problem at all mate. It looks something like this:
Old Feb 7, 2015 | 04:45 PM
costina's Avatar
costina
Stu, When you was mapping the crystal blue saff, was James in the car???
Regards
Paul
Old Feb 7, 2015 | 10:36 PM
tony66's Avatar
tony66
Default chip/tune
ensure chip is of good known origin[msd,collins etc]
check basic engine is up to coping with the upgrade
make sure fuel pump is getting good power supply[nice fresh pump harness helps]-new quality fuel filter and good strong pump
set fuel pressure to chip providers spec[normally standard]
make sure plugs/leads/cap/sensors all a1[plus all connections]
make sure all hoses/clips pipework secure -particularly fpr/actuator related
set co to chip providers spec
set boost to level recommended by chip provider
would recommend not held at load for long untill afr/det checked on road or dyno
people wonder why a tune up /upgrade costs a few quid and they put in a car needing lots of work before any upgrades begin...
9 psi isnt a lot of boost on greens...most run 3x that it would seem
when i firs had cossies in late 80s/early 90s stage 3 was 21psi
Old Feb 8, 2015 | 11:15 AM
costina's Avatar
costina
Tony, do you remember the old stg 2 light green conversion. For about 290 bhp.
Old Feb 8, 2015 | 12:12 PM
James @ M Developments.'s Avatar
Regards
Paul
yes thats how we normally do it
Old Feb 8, 2015 | 03:34 PM
costina's Avatar
costina
lol James it just looked odd. Seemed like Stu was increasing throttle with his left hand.
All good stuff eh
Paul
Old Feb 8, 2015 | 03:38 PM
tony66's Avatar
tony66
Default stg 2
yes i do-that was when stage 1 was normally a massive 12-14psi lol
i think it was a "safe" option as generic mapping was in its infancy then
for 5 turbos we just used to wind the boost up using the actuator and use pallet banding to help hold the intercooler together[plus unplug the boost protection sensor]-as far as checking the fuelling well erm...we didnt in those days
Old Feb 8, 2015 | 05:47 PM
costina's Avatar
costina
Its come a long way since those days but its still easy to kill a cossie if set up wrong.
Theres was a fella around here had many cossies that every engine had blown. He bragged his chip that he used was a cossie killer.!
Muppet....
Old Feb 9, 2015 | 09:41 AM
All good stuff eh
Paul
I assume you mean this one Paul?
Basically, in that mode, I tell the dyno what revs it should allow the engine to accelerate to and then I map that area. When im done, I tell the dyno to allow a rev increase of the engine so i can map the next site.
James in this video just holds a steady throttle to control the load site. IE: James adjusts throttle a little to maintain between 7 and 9 psi of boost (5th red box along on the screen) while I also control the dyno in order to ensure the engine is stopped at the RPM site i want it at. So every time I press the up button, the dyno allows the engine to increase rpm by anything I want from 10rpm to 1000rpm. (Set to 100rpm in that video so 3 presses is 300rpm)
The load and RPM control on our dyno is truly awesome and makes mapping an absolute breeze.
Old Feb 9, 2015 | 10:09 AM
costina's Avatar
costina
Cheers mate that clears that up. Very good bit of kit you have there.
Whats the highest bhp so far?
Regards
Paul
Old Feb 16, 2015 | 11:00 PM
Richard89cosworth
Thanks lads will have to see who in Ireland has the right settup to map it
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
