TPS wiring....??????
Hi
Does anyone know how the wires go from TPS to ECU (either L6/PF01 or L8/PF09)??
I know that ECU pin 11 17 30 are used and the the pin numbers on the TPS are marked A B and C ..... but witch pin number (letter) on the TPS are connected to ECU pin 11 17 and 30 ... ???
Which ecu do you have? L6 or L8?
Measure the signal from the TPS at idle.
For the L6 with a PF01 it must be (close to) 5.0 volt.
For the L8 with a PF09 it must be around 0.20 volt.
Hi .. thanks I know
DixieTheKid
11
Jun 6, 2020 11:20 AM
kosienutter
31
Aug 22, 2015 09:55 AM
