will i need to get cosworth set up after fitting new fuel pump
Old 07-05-2013, 11:20 PM
richbogle
richbogle's Avatar
Default will i need to get cosworth set up after fitting new fuel pump
As title says,i have a bosh 044 pump to put on my stage 3 saff. Not sure what pump is on it but it lookd old,the car was on rollers 2 year ago and was fueling ok so wen i put new pump on will i need to have it checked?
Old 07-05-2013, 11:24 PM
Chip
*** Sierra RS Custard ***
Chip's Avatar
Shouldn't make any difference as the regulator should stop it making too much pressure. But get it checked anyway to be sure.
Old 07-05-2013, 11:39 PM
richbogle
richbogle's Avatar
Well thats exactly what i was thinkn mate about regulator...
Old 08-05-2013, 12:15 PM
martysmartie
martysmartie's Avatar
Check the fuel pressure, also have you re-wired the pump?
Martin
Old 08-05-2013, 12:49 PM
richbogle
richbogle's Avatar
Martin
Im gona re wire the pump at same time mate.
Old 18-05-2013, 08:25 AM
Versus_Creations
Ask me a question!
Versus_Creations's Avatar
In theory who ever set the car up last should of checked the fuel pressure with and without vacum. If this was done then it should be set at 3b with vacum and 3.5 without. As long as you matched this back up it should perform as it did before.
From experience this is not always the case and like chip said really anytime you change any component on the engine that "could" effect the setup, it should be checked out.
Gaz 88
Ford Focus RS Parts for Sale.
29
10-05-2017 12:31 PM
kosienutter
31
22-08-2015 09:55 AM
14-08-2015 07:29 AM
dlwarrior
05-08-2015 10:19 AM
CabrioTurbo
01-08-2015 11:04 AM
Quick Reply: will i need to get cosworth set up after fitting new fuel pump
