02 Engine Immobiliser issue
Old Feb 11, 2013 | 10:03 PM
Geoff Brent's Avatar
Geoff Brent
Default 02 Engine Immobiliser issue
My 2002 Fiesta LX has been off the road for a while. I tried to start it (after recharging the battery) and something clicks a few times near the glove box and the immobiliser flashes very rapidly and you get an EAC failure alarm in the clock LCD. Is there anyway to override this?
Any help gratefully received... Many thanks
Old Feb 12, 2013 | 08:57 AM
0150carmac's Avatar
0150carmac
Afraid it sounds like bad news that i recently had a fiesta in for the same thing turned out to be a ecu fault sent it away to bcc and it cost Ł350. To fix had to send ecu key and cluster came back 100%
Old Feb 12, 2013 | 12:25 PM
martysmartie's Avatar
martysmartie
Are you sure the battery is good?
Martin
Old Mar 2, 2013 | 02:34 PM
Geoff Brent
Martin
I have tried to jump start as Ford said the same thing but no joy! I guess I'll have to get it towed in and fixed! Thanks for the suggestions
Old Mar 3, 2013 | 03:56 PM
martysmartie
Yes but jump starting will not help a faulty battery, get it tested!
Martin
Old Mar 3, 2013 | 09:12 PM
Geoff Brent
Sorry Martin, used jump leads from my car and had 14.5v on it, that's what I meant! Still got the same clicking noise which stops after about 8 clicks and then nothing but the flashing immobiliser. Starting to think it may need some professional help. But thanks for your suggestions!
JoeyBoyden
Jan 4, 2024 02:36 PM
gchristophi
Aug 31, 2015 10:36 PM
ekjim
Aug 17, 2015 08:57 PM
Bailes1992
Aug 16, 2015 07:14 PM
yawiejon
15
Aug 9, 2015 06:36 PM
