Boost problem
Old Dec 3, 2012 | 02:48 PM
s2erst's Avatar
s2erst
Default Boost problem
Hello can someone give me some ideas of what can be wrong, im running external wastegate with 11psi spring the problem im having is it will only boost 9psi an not opening the screamer pipe an no matter what i do i cant make enough boost to open wastegate. i have put 3 dif springs in 9psi 14psi and 18psi an everytime it will run 3/4psi under the rated spring pressure ant idea as its starting to do my bloody head in. Oh im running without boost controller just piping it straight from turbo to bottom of wastegate
JK12
33
Apr 26, 2021 12:09 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
