cossie brake issue
Old Oct 20, 2012 | 09:15 PM
JoeRS22's Avatar
JoeRS22
Default cossie brake issue
hello peeps, wondering if anyone can help.... got a 3dr cossie which all of a sudden has no brakes, brake reservoir level high and appears to be no pump operation, fuse appears to be fine, any ideas????
cheers joe
Old Oct 20, 2012 | 09:29 PM
grcossie's Avatar
grcossie
Pressure switch on abs unit, is a common failure
Old Oct 21, 2012 | 11:50 AM
JoeRS22's Avatar
JoeRS22
can you link any of the plugs out to get pump to run (just to test to see if it is the cause) ??
Old Oct 21, 2012 | 12:18 PM
martysmartie's Avatar
martysmartie
Relay? The pressure switch is on the M/C itself, you could bridge the wires, BUT only to see if it runs, if it starts stop, as obviously it won't cut the power when the pressure is high enough.
Martin
Old Oct 21, 2012 | 12:34 PM
JoeRS22's Avatar
JoeRS22
Martin
tried spare relays, and also had a spare abs ecu so plugged that in to but nothing, will try and find me spare brake unit and plug into spare switch me thinks...
Old Oct 21, 2012 | 01:27 PM
martysmartie
That won't work, it's a pressure switch, thus it won't actuate, hence as I say the only way to eliminate is to bridge the connector.
Martin
Old Oct 21, 2012 | 06:45 PM
JoeRS22's Avatar
JoeRS22
ok will try that, thanks martin
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
Bailes1992
Sep 3, 2015 02:17 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
Red_bull
Aug 9, 2015 08:34 AM
