new engine or head gasket
Old Jun 18, 2012 | 10:07 AM
swain78's Avatar
swain78
Default new engine or head gasket
Hi guys was just wondering if it would be easier yo replace the engine or the head gasket.
Symptons i have are whilst driving round town temp sits in middle but fans come.on constantly. On a run at 75ish temp boils right of red line. Slow to 60 drops to normal as.quick.as speed drops
Bought from bloke who said put went and he replaced it. Thwre was no heat from heaters which i sorted by flushing system completely and fillin heater by disconnectin pipe from back of stat housing. Still boiled up. Took stat out now temp sits between 95-116 from the dash trick. Bubbles in expansion tank. So thinking the gasket has gone. But what is the easier job. Pls
Old Jun 18, 2012 | 11:16 AM
rog's Avatar
rog
That all depends if it's a Veyron or a fiesta how much work is invloved. HG will always be easier to do, depends if it's worth it though.
Old Jun 18, 2012 | 11:18 AM
swain78's Avatar
swain78
Oh yeah i forgot bout car its a 2001 focus 2.0zetec
Old Jun 18, 2012 | 11:42 AM
swain78's Avatar
swain78
Sorry just seen what i wrote with my clumsy claws on my fone. It was the pump that failed and got replaced. Was ok for bout 700miles
Old Jun 18, 2012 | 01:45 PM
gjh's Avatar
gjh
I'd say head gasket would be a lot easier. DIY provided you know somewhere to give the head a skim (any engineering shop should be able to do it)
Old Jun 18, 2012 | 01:49 PM
swain78's Avatar
swain78
Cool do all the cams need to come off?
Old Jun 19, 2012 | 07:44 PM
Alvyn's Avatar
Alvyn
have you checked that the actual coolant rad isnt blocked or you've got an air lock in the system? and a head gasket would be far easier imo!
Old Jun 19, 2012 | 08:32 PM
swain78's Avatar
swain78
Have bled system completly ripped rad out and flushed. Refilled according to ford tis. Still boiled up. Put some seal-up liquid glass. Now have hardly any pressure build up but the temp still hits 100c with stat out.. poss pump prob was told it was changed but no guarantee. Looks new though
Old Jun 19, 2012 | 08:37 PM
Mark_'s Avatar
Mark_
Dodgy water pump?
Not sure if these would be the same but the mk4 Golf water pump has plastic impellor which often breaks up,
Or sometimes the pump turns but the impellor doesnt, It just sits on the shaft which is more noticable at higher RPM as the Temp rises
Old Jun 19, 2012 | 08:39 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
does the level rise or differ when reved?
would rule out the pump if you can see its doing something and if the level didnt rise or change then maybe pump probs
Old Jun 19, 2012 | 09:05 PM
swain78's Avatar
swain78
When revvin the level sinks a bit. Randomly will spit a bit of water out when droppin revs
Old Jun 19, 2012 | 09:07 PM
swain78's Avatar
swain78
Did put some of that stupid wondaweld in as local motorfactors was closed. Could this of got in oil causin overheat.
Old Jun 23, 2012 | 09:22 PM
swain78's Avatar
swain78
Given up explored all avenues. Gonna scrap it. Cba with it no more
RUBY123
Oct 22, 2023 12:04 PM
SmudgerByName
52
Jul 28, 2016 06:14 PM
3i Jim
Nov 20, 2015 05:12 AM
Marcus L
Aug 29, 2015 02:18 PM
ekjim
Aug 17, 2015 08:57 PM
