ST170 supercharged problem
Old Jun 15, 2012 | 04:31 PM
st170sc's Avatar
st170sc
Default ST170 supercharged problem
Here is the situation: we bought a trackday kit car powered by Ford Focus ST170 engine with Rotrex supercharger.
First of all I should mention, that my knowledge about this engine is quite limited, since we bought used car in this setup already.
The problem we are experiencing is an excessive amount of oil and air flow coming from the pipe marked on the photo below. (Photo is not from our actual engine)
https://passionford.com/forum/album....ictureid=24318
I guess this is not normal behavior. Any ideas, what could be causing this? Where do start looking for the cause of this problem?
Old Jun 15, 2012 | 04:41 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
looks like a breather, maybe its breathing too much thru the rings. maybe a compression test dry then went, and check any other breathers are not blocked or split
Old Jun 18, 2012 | 09:38 PM
st170sc's Avatar
st170sc
What is the expected compression for this engine?
Old Jul 9, 2012 | 02:34 PM
st170sc's Avatar
st170sc
I thought that I might give you an update on the issue.
We did a compression test and there was no compression in one of the cylinders. After taking the engine head off, we discovered, that mentioned cylinder had damaged piston and scratch marks on cylinder wall.
We will probably go with the engine replacement, since another used engine in good shape is cheaper than the repair.
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
Tank Mike
Ford Focus ST Parts for Sale
May 18, 2016 09:38 PM
Andypandy260
Sep 23, 2015 10:28 PM
pie-face
Sep 15, 2015 10:43 AM
markk
Sep 9, 2015 08:11 AM
