whats the best zetec turbo con rods to use value for muney?
Engine Machinist
you can get rods AND pistons from the states for Ł516 (with todays exchange rate) or rods alone for Ł220
PEC rods as listed on their site are Ł485![](https://passionford.com/forum/images/smilies/shocked.gif)
or these from a seller in this country:
http://www.ebay.co.uk/itm/Ford-Zetec...#ht_720wt_1163
would be absolutely fine! as i said, most are made in the same factory anyway
Bodger of Blackburn
i'm using eagle rods, seem to be fine, taken it to 7200rpm and 20-21psi hasn't broken them yet, going for more boost soon.
revs tend to kill rods and it's likely the oil pump will give up before that anyhow.
i got custom sized wiseco pistons, eagle rods, acl big and main shells for around Ł850 including delivery and tax from the states last year.
i really couldn't argue with that.
Robson Engineering in Coventry are supposed to be the nuts. I believe they make the farndon or similar spec rods
would be absolutely fine! as i said, most are made in the same factory anyway![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
Add shipping costs plus import tax and a outside risk of getting the wrong ones and your not far off the cost of UK ones without the hassle (if you look in the right places)
Engine Machinist
there are probably cheaper ones than those, but thats all i could come up with in my 30 seconds of searching
