smoking zetec turbo
#41
turbovh
yh it should sort the smoking and vcompression problems what sort of boost can i safely run with this sort of set-up? i was hoping for around 10psi still on a stoc map sensor so cant exceed a bar anyway
#42
turbovh
![](http://i1076.photobucket.com/albums/w456/HirenRS/IMG_2236.jpg)
![](http://i1076.photobucket.com/albums/w456/HirenRS/IMG_2237.jpg)
![](http://i1076.photobucket.com/albums/w456/HirenRS/IMG_2238.jpg)
![](http://i1076.photobucket.com/albums/w456/HirenRS/IMG_2239.jpg)
![](http://i1076.photobucket.com/albums/w456/HirenRS/IMG_2240.jpg)
![](http://i1076.photobucket.com/albums/w456/HirenRS/IMG_2241.jpg)
![](http://i1076.photobucket.com/albums/w456/HirenRS/IMG_2245.jpg)
bearing has a few marks but looks like theyve been re-fitted with metal or something stuck around the inside the bearing although look shot aint to bad will be getting replaced anyway had a good look at crankshaft today and it looks good also striped loom etc to spray under bonner whilst giving the body a bit of twopack loving
