Noise from clutch - Focus
Old Apr 11, 2012 | 08:58 PM
Olli2004's Avatar
Olli2004
Default Noise from clutch - Focus
Hi,
I have a 53 plate Focus. When I depress the clutch pedal fully down there is a grating noise. Do these have any issues with the fingers snapping off the clutch plate.
Do these have a Dual Mass Flywheel?
Many thanks
Ollie
Old Apr 11, 2012 | 09:08 PM
RichieST's Avatar
RichieST
TDCIs are dual mass flywheel, rest are solid. Never heard of any common clutch issues, just the DMF's that play up commonly.
Old Apr 11, 2012 | 09:27 PM
Olli2004's Avatar
Olli2004
Cheers for the reply. Looks like the box is going to have to come out then.
Old Apr 12, 2012 | 09:36 PM
Olli2004's Avatar
Olli2004
To remove the gearbox do I have to dop the subframe? Its a TDCI and should I replace the clutch at the same time as replacing the DMF?
Old Apr 12, 2012 | 10:07 PM
GVK.'s Avatar
GVK.
Disconnect the subframe and tie it back, but leave it hanging on the rack, helps get the box out a bit easier.
Your noise sounds like release bearing (part of slave cylinder)
Have you got any DMF issues? (rattling when starting/stopping engine - vibration on acceleration - vibration felt through clutch pedal?)
Might get away with just a clutch/slave cylinder, if DMF is ok.
Old Apr 12, 2012 | 10:11 PM
phil_focus's Avatar
phil_focus
could be just the release bearing being noisy. if you can put up with the noise it can last for years like that.
either way its box out to replace and for the time spent on it you may aswell replace the lot but DON'T buy cheap crap, it doesn't last!
Old Apr 12, 2012 | 10:19 PM
GVK.'s Avatar
GVK.
Agree with that!
Old Apr 12, 2012 | 10:36 PM
Straight_4_N/a's Avatar
Straight_4_N/a
As above most likely the clutch realse bearing and thay last for ages mines been like it for two years and still fine with loads of abuse.
also you dont have to touch the sub frame to get the gearbox out theres more than enough room to get the engine and gearbox out with it still in. (ive done it in a garden just with alxe stands and a jack so its realy not that hard)
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
rsturbo27
Sep 5, 2015 05:08 PM
