Engine rattle
Old Apr 11, 2012 | 03:00 PM
BIL N KEL's Avatar
BIL N KEL
Default Engine rattle
Hi I have a noise coming from my engine which is making me paranoid! The engine has done less than 10k after full rebuild inc new pistons and cams. The lifters were not replaced so could this noise be a lifter?
First video is from cold, been started roughly 30sec
http://s108.photobucket.com/albums/n...t=37562102.mp4
Second video is up to normal running temperature
http://s108.photobucket.com/albums/n...t=45fd07bc.mp4
Oil pressure was 52psi at 2500rpm
Any help is much appreciated
Thanks Billy
Old Apr 11, 2012 | 03:13 PM
MK2 COSWORTH's Avatar
MK2 COSWORTH
hi, that could be lifters always check timing first tho.. take the rocker off and if nothing looks out of place scored or damaged it might be worth changing the lifters,,, or you could put them in a vice and squash the oil out of them as they might have jacked make sure you get someone who has done this before if you havent
Old Apr 11, 2012 | 03:40 PM
BIL N KEL's Avatar
BIL N KEL
does it sound like little or big end bearings worn????
Old Apr 11, 2012 | 03:41 PM
BIL N KEL's Avatar
BIL N KEL
thats what i hope it is! i will get some new ones ordered tomorrow
Old Apr 11, 2012 | 04:02 PM
MK2 COSWORTH
might be worth taking them out first save the pennys these cost enough to run as is lol getting the oil squashed out them might solve the problem i sound like cams not crank but might be wrong
Old Apr 13, 2012 | 11:52 PM
BIL N KEL's Avatar
BIL N KEL
Well I fitted the new lifters earlier and gave it service and it's no better, if anything I think it's getting worse! I spoke to a mate and he suggested it has spun a shell as he had the same noises coming from his and that was the case. I'll pull the engine out in the morning and whip the sump of for a look and see what damage there is
Old Apr 14, 2012 | 07:02 AM
MK2 COSWORTH
bad times mate i noticed a thread recenlty with the same problem.. im still no further forward either with mine
hopper350
Sep 4, 2015 12:53 AM
Bailes1992
Sep 3, 2015 02:17 PM
Roosie
Aug 13, 2015 07:40 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
