Pinto engine question
Old Jan 8, 2012 | 02:22 AM
N.Saph's Avatar
N.Saph
New Ford sierra owner
Default Pinto engine question
do all pinto's tick when started an driving?
this past while i've started hearin it, wen i ease of the accelerater it goes away, wen i accelerate it ticks away
is this normal pinto's?
near sure it did it at the start when i bought the sierra
Old Jan 8, 2012 | 07:59 AM
robrs2's Avatar
robrs2
carb or efi
Old Jan 8, 2012 | 08:18 AM
DAN400's Avatar
DAN400
prob need your tappets set,
just pull the rocker cover off and check them, 15 min job
Old Jan 8, 2012 | 12:04 PM
martysmartie's Avatar
martysmartie
As said the valve clearances (Tappets) most likely need adjusting, you will need a set of feeler gauges, it must be done with the engine cold!
For the correct clearance and the procedure you will need to refer to the manual , it's normally something like you check number 1 valve with number 8 shut.
Martin
Old Jan 8, 2012 | 06:07 PM
N.Saph's Avatar
N.Saph
its a carb engine running twin 40's
changed oil, filter, waterpump, thermostat, coolant an all there few weeks ago
Old Jan 8, 2012 | 10:46 PM
martysmartie
But the tappets are also servicable items
Martin
Old Jan 9, 2012 | 01:35 AM
N.Saph's Avatar
N.Saph
Martin
thats an area im not sure off
Old Jan 9, 2012 | 08:36 AM
robrs2's Avatar
robrs2
Has it done it since the oil was changed?
Pinto's have a bad habbit of getting blocked spray bars. Then the cam is shot.
Old Jan 9, 2012 | 12:24 PM
martysmartie
I'm telling you they are
Martin
Old Jan 9, 2012 | 01:42 PM
N.Saph's Avatar
N.Saph
aye i have heard it since this but not straight after
i have a new kent cam to be fitted with followers so if it is the cam i've been lucky? im using the standard cam at the min with the 40's
N.Saph's Avatar
N.Saph
Martin
yea i mean engine bits an take the rocker cover off is a place i have no idea about lol
Old Jan 9, 2012 | 08:35 PM
robrs2's Avatar
robrs2
Ok if it's since you changed the oil. What grade did you put in. The pinto does not like new synthetic oils or even light grade oils. Especially an old higher mileage one.
If that's what you have done then at a guess the cam is scrap as the lobes will be gone.
You need to take the cover off and look.
Old Jan 9, 2012 | 08:45 PM
N.Saph's Avatar
N.Saph
wat grade of oil should be used?
Old Jan 9, 2012 | 09:41 PM
martysmartie
Oh I see what you mean, yes only the manual can tell you the procedure and clearances, as they are unique to the engine!
I would use 10/40W or 15/50W but certainly nothing either side of these grades.
Martin
Old Jan 9, 2012 | 10:32 PM
N.Saph's Avatar
N.Saph
ummm i needa check what i used
im near sure at the start i used 10-50 which i was told to run a sierra
i think im using 10-40 now
Old Jan 9, 2012 | 10:39 PM
damien roe's Avatar
damien roe
just a guess but would 15/40 of been the oil pinto's started life with as most old engines use it
Old Jan 9, 2012 | 10:57 PM
N.Saph's Avatar
N.Saph
im not sure but could that be the reason?
maybe the thicker oil has maybe stuck/jammed the tappets?
big_Rad
Sep 15, 2017 09:36 AM
bigryrs
Mar 28, 2016 09:11 PM
bigryrs
Fiesta RS1800/RS Turbo
14
Jan 21, 2016 09:54 PM
Ben26
Aug 27, 2015 08:56 PM
wheelwizardrefurbs
Aug 6, 2015 07:40 PM
