xr4i Lifting problem down force help
Old Dec 4, 2011 | 10:18 PM
Dom-hkl's Avatar
Dom-hkl
Default xr4i Lifting problem down force help
HI i was driving my xr4i tonight and the road dips and as i went down the dip i plated it flat out and i felt the whole front end lift up off the floor it is 24v converted so i plants it prity hard and any speed but none the less it was a o f**k second was wondering if anyone had any ideas pictures or knows a good way of keeping the front end down hard on the tarmac as april she goes sprinting so would like to have solved this problem by then o she also has the standard xr4i bumper on at the moment so the front splitter and shape of it probably plays a large part wonderd if anyone had any real good solutions cheers,
Old Dec 4, 2011 | 10:26 PM
YOREVOL's Avatar
YOREVOL
YOREVOL
tbh the v6 is a heavy lump i dont hink youll find a better down force creator than that.
Old Dec 4, 2011 | 11:07 PM
botters's Avatar
botters
competant bodger
it used to be the backend that lifted on my xr4 quite scary at over 100mph when it lifts and goes sideways without even a moments notice! never had a problem with the front, my guess is your shocks are fucked and your springs are too soft
Old Dec 5, 2011 | 10:39 PM
Dom-hkl's Avatar
Dom-hkl
Has Koni adjustable dampers and brand new 40mm drop springs the non progressive type so its pritty stiff it holds onto the road pritty well , in the dry anyway
Old Dec 5, 2011 | 10:45 PM
Dom-hkl's Avatar
Dom-hkl
It was quite a windy day i might add we were doing about 140 so is the cosworth bumper the best one to strap to the front with the race lip on it
Old Dec 5, 2011 | 11:12 PM
hogdog's Avatar
hogdog
Sounds exactly like what I used to experience in my MK1 Focus at 100+mph...Scary!
In my experience lowering really helps as it stops too much air getting under the car but a front splitter helped massively too, it felt much more planted at speed.
The XR4i front bumper really looks like it will direct air under the car so I reckon a Cossie bumper with splitter will help alot.
Old Dec 6, 2011 | 07:56 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
No idea what your troubles are but mine don't do it and i have a bit more power than you as well.
Steve
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
