C20LET pistons
Old Dec 6, 2011 | 08:35 PM
maRtins.Pt's Avatar
maRtins.Pt
Default C20LET pistons
hi
i have a doubt.
in the fiestaturbo.com i saw information about conversions for turbo in this case zetec turbo.
Originally Posted by fiestaturbo.com
With forged pistons there are a number of options for the Zetec. The cheapest is to use those originally designated for another type of turbocharged car. In this case the most common source for 2.0 pistons is the Vauxhall C20LET from the Cavalier and Calibra Turbo. Fitted to a Zetec these will give a CR of 7.4:1
The C20LET bore is 86mm, compared to the 2.0 Zetec's 84.8mm, so a slight overbore of the block is required. This presents no problem as the block is likely to have some wear on it and there is enough material to maintain the wall thickness. This will take the original 1998cc to 2045cc. Also required is modification to the rods to accept the 21mm wrist pin.
my question is, can i use C20LET and the CR will be ok (CR- 7.4:1 is true) or i need to Skimmed the pistons?
what is the difference in C20LET and C20XE pistons? i know that C20LET is forged, but C20XE i dont know?
many thanks
Nov 1, 2015 06:53 PM
little bram
Oct 4, 2015 12:13 AM
deathrider666
Sep 28, 2015 06:12 PM
timsrs
22
Sep 24, 2015 08:14 PM
ajamesc
Sep 8, 2015 06:51 PM
