Cvh running problems
Old Nov 22, 2011 | 04:47 PM
Fordmad!'s Avatar
Fordmad!
Default Cvh running problems
Xr3i efi
Misfires, stalls, no power won't rev!
Changed the crank sensor (new one)
Have good spark across all 4 new plugs
Changed the coil pack and map sensor. Checked pipes for air leaks.
Fuel pump primes as it should
Changed tps
Changed sensor in thermostat housing. Need to try air tempurture sensor, have one to try.
All sensors are off another engine and seem in good condition.
Plugs seem dry and black even tho they are new and you can smell fuel so it could be over fuelling?
What else can i check for its driving me mad!!
Old Nov 22, 2011 | 05:55 PM
Fordmad!'s Avatar
Fordmad!
Can anyone help me?
Old Nov 22, 2011 | 06:14 PM
lockie's Avatar
lockie
ecu
either get a replacement or get it sent off & re-programmed had the same thing on my brothers years ago.
runs asif timeings a million miles out, slutters coughs wont rev but has spark & fuel. its timeing issue in ecu, happend overnite randomly?
Old Nov 23, 2011 | 06:42 AM
Fordmad!'s Avatar
Fordmad!
Yeah i changed i bought it home after having it resprayed and it was fine then started it up in the morning and it just started playing up, it hadnt moved, like you say baisically happened overnight!
Old Nov 23, 2011 | 05:15 PM
Fordmad!'s Avatar
Fordmad!
Started the car up this morning and it ticked over perfect! Left it for 5 minutes and it was fine so took it down the road and on the way back it started playing up again!!!!
It seems to pley up when it gets warm! Ive been told its the crank sensor although ive tried replacing this already!
What cold cause the problems when warm?
Old Nov 23, 2011 | 06:31 PM
GVK.'s Avatar
GVK.
Did you have any welding done as part of respray?
Wondering if they've spiked your ECU by welding with battery connected?
Old Nov 23, 2011 | 08:10 PM
Fordmad!'s Avatar
Fordmad!
Yeah had the battery tray done but engine was out and battery was last thing i put on
If it was the ECU wouldnt it constantly play up or only after running for awhile?
Old Nov 24, 2011 | 07:35 AM
Fordmad!'s Avatar
Fordmad!
What could cause the car to only play up when its warm?
Old Nov 24, 2011 | 10:16 AM
lockie's Avatar
lockie
get the ecu tested or repalce it.
if you want to fix it yourself its trial/error, if u dont want 2 mess about then give it 2 a garage 2 sort out & just pay the bill at the end.
Old Nov 24, 2011 | 01:33 PM
Fordmad!'s Avatar
Fordmad!
Will a diagnostics test pick up a faulty ECU?
If the ECU was at fault then wouldnt it play up all the time and not just when its warm?
Old Nov 24, 2011 | 01:34 PM
Fordmad!'s Avatar
Fordmad!
I read in the haynes manual that sometimes the ECU can reset itself and needs running back in? Anyone else ever had this problem?
Old Nov 24, 2011 | 04:34 PM
lockie's Avatar
lockie
when my bros car went wrong we took it in local garage with best diagnostics gear, they said ecu needed to be reset & it had 2 get sent off to be done, a week later it came back & car was ok. (Ł70 all in)
cant see why you cant buy a 2nd hand ecu from breakers/ebay for Ł10-20 & plug it in thou as not coded like newer cars
Old Nov 24, 2011 | 06:36 PM
Fordmad!'s Avatar
Fordmad!
I don't mind a diagnostics test aslong as it finds the problem out.
I will try and get an ECU. Does it have to be off a car the same year?
Old Nov 25, 2011 | 07:49 AM
Fordmad!'s Avatar
Fordmad!
Just taken my ECU out of the car. Does anyone have a number/website i can contact so i can send it off?
Old Nov 27, 2011 | 02:28 PM
AstoN_B's Avatar
AstoN_B
An eye for detail...
Might be worth trying the air and water temp sensors for the ECU too, water temp is in the manifold above oil pressure sender.
Old Sep 10, 2012 | 08:39 PM
mogfocus44's Avatar
mogfocus44
I have a 1.6 cvh efi.
It has an intermittent fault.
Wehn it reachess 2000 rpm the engine dies back but will then pick up again.
Always at about 2000 rpm. When on positve throttle it carries on revving as normal but when over 2000rpm it dies back if there is the slightes throttle lift.
Any similarities here?
I have not had a diagnostic done yet but done simple checks
only so far.
Old Sep 10, 2012 | 08:43 PM
mogfocus44's Avatar
mogfocus44
My 1.6 cvh efihas a similar problem but....
Intermittently when it reaches 2000 rpm the engine dies back but will then regain and run, but dies back when 2000 rpm reached again
It runw well up this rev level and idles normally. I can poodle along up to 2000 rpm and no problems. Also, when on positive throttle it will go cleanly past the 2000 rpm but dies back at the slightest lift off.
TPS?
Spark is good and coil primary spot on - haven't checked coil secondary yet.
No vacuum leaks detected so far.
No diagnostic done yet - its Ford 3 - pin connection but haviing a hard time finding a diagnostic unit.
Old Sep 17, 2012 | 08:31 PM
Murph81's Avatar
Murph81
Mk4 XR3i EFI
Hi All,
Just rebuilt the head on my 1990 CVH EFI and the Idle Control Valve (side of inlet manifold) was really gunked up. Would be worth taking off and soaking in petrol overnight to clean out. If this piston and spring is sticking or snagging it may not help. Easy check and worth cleaning if not done so.
Old Sep 18, 2012 | 11:32 PM
AstoN_B's Avatar
AstoN_B
TPS?
Try a different map sensor and tps.
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
Ben26
Aug 27, 2015 08:56 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Zoggon
Aug 10, 2015 10:39 AM
knight19770
Aug 4, 2015 12:36 PM
