Gearbox screaming at me.
Old Nov 20, 2011 | 09:50 PM
mgsdetail's Avatar
mgsdetail
Default Gearbox screaming at me.
Last night my gearbox seem to start screaming at me when I come of power, but fine if you put your foot down again.
The sound is a high pitch whine and only happens when slowing down in gear.
My clutch release bearing has got louder over the past couple of weeks but nothing to bad.
One thing I did notice today was that when in reversing the car seemed to skip and bang unless I gave it more revs.
Do you lot think it's new gearbox time or could it be the release bearing and a very low clutch.
Thanks.
Old Nov 23, 2011 | 09:22 AM
IceCage's Avatar
IceCage
Question
hello,
I have similar issue with my 75k km F. Ka.
Once I switched to winter slicks I don't have any more wheel sounds inside so I hear clear whine of diff:
while accelarating
while using engine as break (deccel)
there's just some sound from clutch bearing, its well-worn but not grinding yet, so that is not the issue.
I took my old man (he is car technician for all the time I know him ) to have a ride with me and he said that for this small car with FWD it's nothing weird: gearbox is slightly used, so it will whine. But no problems with bearings, that should be different sound (rumble, grinding etc.)
I remember this type of sound from homebuilt tractor, very common differential whine, nothing bad. (Wheels/axles just doesn't fit perfectly anymore to each other, causing some forces to bend the axles, causing extra friction etc).
but that is very imho... I am not expert at all.
timsrs
Nov 13, 2018 11:48 AM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Mark_
40
Oct 2, 2015 04:40 PM
Iain Mac
Sep 30, 2015 09:39 PM
